Supporting Vendors Products and services, available for purchase from registered vendors.
Limited Edition RE30 and CE28
Old 07-10-2008 | 09:39 PM
  #46
Lou@Amplified's Avatar
Lou@Amplified
they all came in today..
oh yah.. thats a jp front lip on top of the 5 sets we got.
Thank you for the orders
Old 07-10-2008 | 10:00 PM
  #47
fkat's Avatar
fkat
Can the OEM Potenza RE050A fit on these RE30 19x9J+38 and 19x10J+38?
Another question about offset. I measured my OEM and got about:
11mm from tire to fender (front)
15mm from tire to fender (rear)
According to my calculations:
19x9+38 will stick out 11.35mm compared to OEM front
19x10+30 will stick out 19.7mm compared to OEM rear
So front seems ok but the rear seems a little too much. Am I wrong?
Old 07-10-2008 | 10:04 PM
  #48
Lou@Amplified
the rears are 19x10+35 offset.
Old 07-10-2008 | 10:05 PM
  #49
GiGGaplease's Avatar
GiGGaplease
its going to sit flush. my rims are 10.5+30 and it sticks out 1/2 inch from the fender.
amp, do you have a set of ta's or le's? price shipped to 70454 if you do.
Old 07-10-2008 | 10:08 PM
  #50
Da Hashi's Avatar
Da Hashi
the oem 245 rears will fit the fronts 19x9 with alittle stretch but you will need at least 275/35 for the 19x10
Old 07-10-2008 | 10:10 PM
  #51
Lou@Amplified
Yes, 10.5 is half inch bigger with +30 offset will stick out .5 inches
10 inch wide, with +35 offset will sit flush.
LE'S are discontinued, Did you mean the TE?
Old 07-10-2008 | 10:27 PM
  #52
Da Hashi's Avatar
Da Hashi
Originally Posted by MoDat
Price shipped to 07871
wassup dude jus wondering what color is your G?
Old 07-10-2008 | 10:41 PM
  #53
fkat's Avatar
fkat
Thanks for correcting. So it's even worse. It would stick out like 8mm or so then. Can these rear wheels be used even if you lower with like S TECH?
Old 07-10-2008 | 10:46 PM
  #54
Lou@Amplified
+35 offset means is 5 less than +30. yes in terms of offset, numbers are reversed.
Old 07-10-2008 | 11:03 PM
  #55
GiGGaplease
nah, i meant the le's. like to have some lip. i know theyre discontinued but there still out there.
Old 07-10-2008 | 11:08 PM
  #56
fkat's Avatar
fkat
OK. Flush is good for me. Are you lowered with those?
Old 07-10-2008 | 11:45 PM
  #57
Da Hashi's Avatar
Da Hashi
fkat at 35mm offset with a 10" wide rim it'll be 23mm from where your rims are now
Old 07-10-2008 | 11:54 PM
  #58
fkat's Avatar
fkat
I agree with you. (9*25.4/2-45) - (10*25.4/2-35) = 22.7
I measured around 15mm on my stock so I said it would stick out about 8mm. So this RE30 won't be flush and if I lower the car then I might rub and maybe have to cut some felt off. I wanted to know that I'm thinking correctly.
Old 07-11-2008 | 12:01 AM
  #59
GiGGaplease
nope i am not lowered. if i want to lower, i would really have a negative camber. 2 finger gap in the rear, 3 fingers gap in the front. so its not that bad.
Old 07-11-2008 | 12:15 AM
  #60
Da Hashi's Avatar
Da Hashi
i'm tucking 275/35 in the rear 245/40 fronts at less then a finger....with my re30s i'm going 285/30 rear and 255/35 fronts....no probs.....hardly any camber in the rear with my 275
