Just to clarify you only did front because our rears are Pre rolled correct ? Also your not rubbing aggressive offsets what's the reason you rolled ? Even me at +15 b4 up front didn't need to roll!
You do gain half inch more clearance from what I understand but I have not found necesary although back in the day w my +5 and 225/35 that would be needed
Sorry late reply...
I'm 20 offset in front, near slammed with perfect stock alignments. My front and rear do not exceed -1.1. So when your tires in front are straight they will rub in fast turns as low as I am. That's why I did it. Not many Gs as low as me with perfect tire wear.
