FS OEM IPL G37 R&L Front Upper Control Arms
Old 01-10-2014, 11:51 PM
IPL G37
IPL G37's Avatar
Category: OEM Parts
Price: $1
Location (State/Prov): NC
Up for Sale are A Pair of 2012 OEM IPL Infiniti G37 R&L ( Both Sides ) Front Upper Control Arms.
These OEM IPL Arms were removed the day the car was purchased.
These Arms are New IPL OEM Parts with Test Drive Miles Only.
SOLD!!!! Mods, Lock It UP!!!!!!
Thanks.
IPL G37 is offline
Old 01-11-2014, 01:41 AM
BeefMaster
BeefMaster's Avatar
Is there a difference between these and the regular arms that come on the sport/base model ?
BeefMaster is offline
Old 01-11-2014, 01:46 AM
IPL G37
IPL G37's Avatar
They fit a lot of different models these were one that were on my IPL, but thats all.
They fit the same for sure.
IPL G37 is offline
Old 01-11-2014, 03:42 AM
gyukang2
gyukang2's Avatar
If you install these on regular couoe, you wont get a right allignment setup.
gyukang2 is offline
Old 01-11-2014, 04:34 AM
IPL G37
IPL G37's Avatar
I don't know that to be true.
Because the parts are the exact size in dimension.
If anyone else knows for sure feel free to chime in.
Nevertheless, the item is true and accurate, IPL Front A Arms that are New.
They came off of an IPL G37 Coupe.
IPL G37 is offline
Old 01-11-2014, 05:15 AM
IPL G37
IPL G37's Avatar
Clarification
To clear up any Issues that may arise from the alignment issues….
I cannot see any reason that would be an issue when tonight I did a search on Infiniti Parts Online and the IPL Upper Control Arms And Regular G37 Coupe Arms Are in FACT interchangeable replacement parts.
So anyone please feel free to verify this for yourself.
But there would be no way it would affect alignment unless the arm were longer or shorter and a direct replacement part will not affect alignment unless you raise or lower the car.
Again, in this case it is the same replacement part per Infiniti.
IPL G37 is offline
Old 01-11-2014, 03:11 PM
gyukang2
gyukang2's Avatar
They look almost same, but ipl one has little bit different angle at the end. I needed one lastweek for my regular g and dealer sent me ipl one by accident. I had to pick up another one again.... Again, they look same, but the end has little different angle, which causes allignment issue
gyukang2 is offline
Old 01-11-2014, 03:13 PM
gyukang2
gyukang2's Avatar
Im not saying yours is not a real ipl control arm. I kust want people know ipl one just fits to ipl.
gyukang2 is offline
Old 01-11-2014, 03:21 PM
IPL G37
IPL G37's Avatar
Ok...Thank you for the Input and its Helpful too…
I will agree to disagree though… Anyone here knows that a lot of people do not run front camber correction kits at all… correct.?
So, My point is... If you are lowered at all… whats the difference.? There is not any correction for alignment in the front end once you lower the car At All.
At least Not with Any stock Arms.
Having said that, if you are Correct and Infiniti is Wrong, then this would only relationship to a stock coupe would be one with no suspension mods… At All.
that would be the only sense to this point here on the issue.
But if you are lowered or on coils and dropped any, the only way even with stock Front Upper Control Arms would be to replace them with SPC upper arms or other front camber arms… If your front end alignment is an issue.
These again are brand new IPL Upper Control A Arms, and I will stand behind my products and offer help to any buyer.
And the point of this is for someone looking for Infiniti Upper Control Arms
for an IPL or replacement Infiniti parts.
If anyone is interested offer all IPL parts together in a set for purchase.
If anyone is interested at all please let me know.
I will again accept reasonable offers.
Thanks everyone… and I hope people find this informative at best.
IPL G37 is offline
Old 01-12-2014, 12:28 AM
IPL G37
IPL G37's Avatar
Bump Bump...
IPL G37 is offline
Old 01-13-2014, 05:12 AM
IPL G37
IPL G37's Avatar
Bump. I will accept offers. Thanks.
IPL G37 is offline
Old 01-14-2014, 12:49 AM
IPL G37
IPL G37's Avatar
Bump. Any offers..?
IPL G37 is offline
Old 01-15-2014, 01:34 AM
IPL G37
IPL G37's Avatar
Bump. Still available.
IPL G37 is offline
Old 01-15-2014, 05:58 PM
IPL G37
IPL G37's Avatar
Still available, accepting all offers.
Thanks.
IPL G37 is offline
Old 01-18-2014, 01:22 AM
IPL G37
IPL G37's Avatar
New lowered Price. BUMP.
IPL G37 is offline
Quick Reply: FS OEM IPL G37 R&L Front Upper Control Arms
