FS Rear Camber and Toe lockout tabs.
SPL Rear Camber and Custom Toe lockout tabs.
Price: $50
I bought the SPL camber toe lockout kit, only used 4 of the lockout plates for camber, as I had adjustable camber arms.
Rather than using the other 4 centered lockout plates for toe, I had some made on a waterjet cutter, with an offset hole to emulate my present toe bolt position.
I wanted to use adjustable traction arms, but leave them as close to OEM length as possible to avoid changing caster, and causing bump steer.
I just left the alignment shop, and I was no more than 1/4 degree off on toe, and camber, which was adjusted with the camber arm.
This will work best with a drop using Swift or Eibach springs, no others, as it would be too low.
What I am selling are the 4 plates that I did not use (for camber), and the 4 extra plates I had custom made using T6061 aluminum. (I did not bother polishing them!) for toe.
You would just need bolts, and adjustable traction arms to eliminate the eccentric adjusters.
They are perfectly square, the damn iPhone distorts.
Installed pic:
IMG_0475.jpg?t=1352578578
m3clubracer
09-13-2015 09:01 AM
