FS Eibach Pro-kit Sedan lowering springs
Price: $150
Part fits: 2010+ G37 Sedan
Location (State/Prov): AZ
I have springs off of my 2010 G37S Sedan. I bought them new and used them for no more than 13k miles. They are part #6390.140.
150 shipped to lower 48.....they do weight 41 pounds, so that's not a cheap ship!
factory box w/manual that came with it.
Ride height!
Last edited by Hotrodder00; 10-20-2012 at 12:25 AM. Reason: didn't save the correct state
The car is going off lease, and I'm not getting another G so I don't need them. I did not need a front camber kit at all and had no problems, slight cupping on the front tires (inside tire wear). The rear they got pretty close to spec without a kit but I didn't like the look of it, so I eventually put SPC adjustable rear arms on and was happier with the look.
Do you have alignment specs by chance? Interested to hear what camber your fronts and rears were set at prior to the rear camber kit. If front could come close to factory camber specs, I'd buy them. With front tires cupping, it sounds like they may have been more negative than recommended specs.
I don't have the numbers from the car, sorry. I'd go get it measured but they're off the car already. Definitely depends on the shop, too. Here's another member's post.
https://www.myg37.com/forums/brakes-...g37-coupe.html
Hope that helps!
Hope that helps!
