Little work on the Nismo diff cover
Old 04-18-2014 | 11:41 PM
VRG37S's Avatar
VRG37S
Had some free time today and decided to clean up the nismo diff cover a bit before installing it along with the diff bushings. The oem cover was in pretty rough shape, tons of casting flash and little imperfections. After polishing the cover a lot of the imperfections are removed, however it's not perfect. Definitely looks nicer though
Attached Thumbnails Little work on the Nismo diff cover-nismo-1.jpg   Little work on the Nismo diff cover-nismo-2.jpg   Little work on the Nismo diff cover-nismo-3.jpg   Little work on the Nismo diff cover-nismo-4.jpg   Little work on the Nismo diff cover-nismo-5.jpg
Old 04-18-2014 | 11:44 PM
Very nice indeed
Old 04-19-2014 | 12:59 AM
VRG37S's Avatar
VRG37S
thanks man
Old 04-19-2014 | 06:54 AM
Presto's Avatar
Presto
How about sharing the products use and the polishing process as well?
Old 04-19-2014 | 07:01 AM
G37Sam's Avatar
G37Sam
Did you weld a bung for an oil temp sensor?
Old 04-19-2014 | 09:48 AM
^^^What he said.^^^
It looks great but if you don't tell us how you did it, you're just showing off and not helping.
Old 04-19-2014 | 05:30 PM
VRG37S's Avatar
VRG37S
Process used for polishing cover
- Use a die grinder/air sander with abrasive an abrasive disc (either 36 or 50 grit will work fine) as aluminum is on the softer side for metals.
- Clean up all the imperfections that are left from the casting mold
- Hook up a wire wheel and detail all the cracks and crevices to remove some of the oxidized metal on the surface
- Now go back to the air sander and use a scotchbrite (Fine grade) sanding disc. This will eliminate and blend in all the sanding marks from using the previous heavier grit discs.
- Now use this process with multiple size discs ranging from 3" for easy to reach areas and down to 1" for hard to reach areas.
- After you feel that you've cleaned up and blended the imperfections to your liking proceed to polishing.
- U can pretty much polish this whole cover with 3 wheels. ( You can see the wheels I used in the picture, the ones that are black from the polish residue)
- You can use whatever polish you want. I use Adams detail products for maintain my DD G coupe. So I use the #1 first and then proceed to #2 to give it a little extra bling.
Hope this helps whoever would like to do this to there cover, total time including lunch break was 4 1/2 hrs.
Attached Thumbnails Little work on the Nismo diff cover-polish-materials-1.jpg   Little work on the Nismo diff cover-polish-materials-2.jpg
The following 3 users liked this post by VRG37S:
Black Betty (04-20-2014), blnewt (04-19-2014), Presto (05-14-2014)
redlinernyc
02-29-2016 11:06 PM
Amrit.bhathal
Car Care & Detailing
12-29-2015 12:20 PM
tomro99
11-17-2015 02:08 AM
ZachThomas
09-03-2015 01:40 PM
Amrit.bhathal
09-01-2015 07:03 PM
Quick Reply: Little work on the Nismo diff cover
