I thought the first pic had the wheels in white. Now that is hot. This is definitely different. It's blowing my mind actually. Just being different pulls it off I think.
Was it a must to run -3 camber w the +25 and 275? Have u trimmed rear bracket ? U rubbing? Looks great nonetheless ! Just right IMHO ....
i swear i could of ran a high camber setting but i guess the guys at the alignment shop were just cautious. my bumper bracket is trimmed and out of the way too so no rubbing at all. now that i look at it there's plenty of room for a higher camber setting. i'll try -2 camber when i get new tires but -3 camber was the lowest i would go too. i wanted some comfort, driveability, and even tire wear since the roads here suck and it's daily driven.
great info on the tires sizes and camber. This is the route I am going
thanks. i'm glad i can help out. its a setup best of both worlds. comfy ride of meaty tires with minor stretch but still gives a decent aggressive stance
Yup, I have ran the Falkens +25 275/30 before but wasnt sure if the hankooks would fit until now. Perfect stance.
Hey what is your ride height from ground to fender in F and R? What camber kit do you have? Did they dial it in exactly to -3 in the rear?
I dont have the height measurements from ground to fender.
I have SPC camber kits front and rear. But I didnt drill and install the elongated bolt. Everything was dialed in fine for the alignment anyways.
They dialed in the rears at -3 for both sides exactly. But if you are running Hankooks 275/30R20 for the rears like i did there should be more than enough room for clearance.. (with the assumption of you having the bumper bracket shaved off already).
Yes, have the 275/30 Hankooks. Thanks for the info. If you ever have a chance to measure let me know, or let me know how many inches you dropped it F and R. Thanks again.
