Autokits Sideskirts & Diffuser Pictures
Old 09-08-2011 | 02:23 PM
911turbo's Avatar
911turbo
Dam....... that has to be one of the best VR's ive seen!
Old 09-08-2011 | 02:24 PM
emyrl's Avatar
emyrl
Thanks guys!
Originally Posted by GraphiteG37S
Wow... best looking VR I've seen. Looks great. I really starting to like the AK sides and rear diffuser. Can you get more shots of the diffuser from the back?
Rear wheels are 10.5 +37 right? I'm thinking of taking out my spacers to slam it like yours. What offset you running up front?
I'll try to get more shots tonight or tomorrow. Making the drive from NorCal to SoCal in a bit today so will be a little busy . Yea my rear wheels are at 10.5 +37 right now. I don't think im that slammed am I? I plan on going stretched tires and putting on spacers once I get those new tires in a few months. My offsets up front are actually 9.5 +25 right now, I have a 10mm spacer up front.
Since everyone's asking I'll tell you guys what some of the issues are. The sideskirts line up fine and everything but the problem is how they are held on. The brackets that come with the sideskirts are EXTREMELY delicate. If you unclip the sideskirt 2-3 times these brackets WILL break off. 2-3 of them are already broken. Second issue is the sideskirts aren't even held on properly along the door. One, the OEM clips that come off the OEM sideskirts are basically one time use. You take off the sideskirts and they are done for life. You need to get new ones. I didn't figure that out until my sideskirts were already on. I went and bought new ones from the dealership and each OEM clip is $3.20. Tried those on and the clips along the door STILL would not go in. I just contacted Alex from Autokits last night and I was told that I was not sent the clips that they used to hold the sideskirts on. A little annoyed, but hopefully those clips that Alex is sending will work. You can't really tell but I currently have blue tape along the sides to stabilize the sideskirt along the door.
Old 09-08-2011 | 02:28 PM
emyrl's Avatar
emyrl
I do remember noticing the gap under the door being slightly bigger than the OEM gap but nothing drastic. Everything else lines up perfectly flush with body. The section by the rear wheel actually lines up better than my OEM sides. It s a real nice set up and I d definitely mold that front for a clean look.
Yea that's true. A molded front would definitely be very clean, though I think I'm going to go with a more aggressive lip in the future
Old 09-08-2011 | 02:49 PM
GraphiteG37S's Avatar
GraphiteG37S
^ Same here.. thanks for the info bud. Looks great!
Old 09-08-2011 | 03:34 PM
emyrl's Avatar
emyrl
No problem man! thanks
Old 09-08-2011 | 06:37 PM
VRG37S's Avatar
VRG37S
Car looks great man. Keep up the good work
Old 09-08-2011 | 07:49 PM
_ant_'s Avatar
_ant_
Great work man love it.
Old 09-08-2011 | 10:51 PM
soolman32's Avatar
soolman32
Not sure how much this will help you but here s some shots of mine for reference. Again I think fitment on these is spot on. Talked to the shop and the actual installer wasn't there but the manager said that they were very impressed with the quality of the product and fitment and that he does not recall the installer mentioning anything negative about the brackets.
Old 09-08-2011 | 11:57 PM
DCook42's Avatar
DCook42
The rear diffuser looks HOT HOT HOT and the red is really poppin'! I hope you get the issues resolved, a quick look to an uninformed eye looks really really good though!!! KUDOS! (the only thing i would add is tire shine, and that's ez
Old 09-09-2011 | 07:09 AM
emyrl's Avatar
emyrl
Thank you for the reference pictures. The fitment of the Autokits sideskirts is very good when compared to certain other aftermarket body parts. It just requires a little modification for it to work. However, in my opinion the brackets are too weak. But this is also almost no different than the OEM sideskirts as the OEM sideskirt's brackets also break easily if you decide to pop the sideskirts out rather than using a panel popper to unclip the clips.
Thanks! I love that you all like the red, if I got a true detail on the car it'd be even more poppin. And tire shine is definitely needed. These tires are about to be replaced soon, so I'm just waiting on that
Old 09-09-2011 | 07:25 AM
emyrl's Avatar
emyrl
And also, I will post up a proper review for both the sideskirt and diffuser once I get everything solved and done. I've discovered that some of the issues I'm having also applies to the OEM sideskirts as well. So this also falls over to the original design of our car's sideskirts. More pictures to come later!
Old 09-09-2011 | 09:07 AM
soolman32's Avatar
soolman32
Good to hear stuff is being worked out.
Old 09-09-2011 | 01:27 PM
WPPJR30's Avatar
WPPJR30
Clean car. Nice photos!
Old 09-09-2011 | 01:35 PM
  #29
kaoticdemize's Avatar
kaoticdemize
very nice car saw it at my dealership the other day
Old 09-09-2011 | 04:00 PM
  #30
emyrl's Avatar
emyrl
Thanks guys!
Haha no way, Beshoff? Yea I was there buying the OEM clips for the sideskirts, which btw do not work very well.
Quick Reply: Autokits Sideskirts & Diffuser Pictures
