project kic spacer installed
Old 09-27-2009, 11:56 PM
  #31
Staples
Staples's Avatar
i guess i got lucky. i went over 80mph and there's no vibration. plus i don't have hubcentric rings also. maybe you should try to install it again, the nut's might not be even and probably causing vibration.
No it's actually because I'm still running the OEM 19s. The Hub inside the wheel is pretty extended, and if you aren't running a hubcentric ring that extends all the way into the wheel it'll cause the vibration. You're not having any issues because you have aftermarket wheels.
They look bad *** though!
Old 09-28-2009, 12:15 AM
  #32
Weiboy718
Weiboy718's Avatar
is there a fix to it? i know there's other members on here got spacers with no vibrations. good luck and thanks.
Old 09-28-2009, 12:18 AM
  #33
Staples
Staples's Avatar
http://g35driver.com/forums/v36-diy/...ation-fix.html
That's the link to the fix. It works pretty well from what I've heard, we'll find out.
Intake
12-25-2015 09:38 PM
news1213
12-16-2015 11:06 AM
NeverBoneStock
09-02-2015 07:19 PM
cparise
08-19-2015 01:51 PM
Quick Reply: project kic spacer installed
