Yes, I had it to where the bottom of the car including the cats exhaust, gt spec everything literally sitting on the floor, like you can't put a finger underneath, thought it was too much so I raised a bit. And btw in the last pics i just posted I can go lower in the rear a little bit more also. But as for adjusting for the system itself to where my lowest drop will be, yes i could adjust it to where my bags drop and land even more lower. But I'm so low right now you can only fit 2-3 fingers under the front bumper.
The coupe is absolute fire. But that rear wheel on the sedan looks retarded. Looks like the bead isn't even seated on the rim. Seems dangerous! It is clean though!
