FS Cooler master csx limited edition
COOLER MASTER CSX LIMITED EDITION Hell Razor Stacker ATX Full tower -
It would be a great Christmas present for a gamer - the MSRP on it is 999.00 but can be found on various sites for less, with shipping around 350.00 to 400.00
Rylan and I would like to get 250.00 for it to do further mods on our cars.(since Dave is cutting us off ) if you are interested call or email me and feel free to pass this on to any one you know who might be interested. it is pretty cool looking in a spooky kinda a way
THANKS SO MUCH -
Maria
these are stock photos I can take some if any one is interested, or come by and see it
Description:
These radical flames are unlike any other. Each one is intertwined with vicious expressions from demonic creatures. From the canines of their dentures to the look in their eyes, this chassis creates awesome, yet unruly scenery. The Flaming Skull is done on a CM Stacker 830. CM stacker 830 has proven to be the leader among all chassis with its streamlined aluminum design and extremely powerful functionality. This ground-breaking chassis is designed with value-added functionality, unmatched upgradeability, tool-free user friendliness, and the superior thermal management.Features
Custom Paint
Hand air-brushed red flaming skull theme
Automotive grade paint use in production
Wax-able top coat
Limited quantity produce for it collectibility factor
Value-added functionality
Front panel opens to the left or to the right for easy access
Power supply may be installed up wards or downwards for better airflow and neat cable management
Unmatchable upgrade ability
Supports up to nine 5.25" drives
Multi-Positioning for the 4-in-3 device modules, providing maximum flexibility in the use of space
Tool-free user-friendliness
Screw-less slots
Exclusive fan frame design provides easy screw-less assembly
Side-opening design for remove 5.25" shield easily
Superior Airflow
Accommodates up to nine 120mm fans
High ventilation openings on the top and the sides for excellent thermal Management
Innovative Style
The match of silver and black colors enrich the whole appearance
Solid construction and streamlined aluminum design
Detail Spec
Available Color
Custom hand-painted (air-brushed) Hell Razor Stacker w/ clear window
Dimension (L x W x H)
30" x 28.4" x 17.4"
M/B Type
E-ATX, ATX, m-ATX,
Material
Aluminum : 1.0 mm
Weight
Net Weight : 29lbs ; Gross Weight : 48lbs
3.5" Drive Bay
4 (Hidden) from one 4-in-3 Device Module included;,
Two 3.5 face plates included
5.25" Drive Bay
9 (Exposed)
Cooling System
One 120x120x25 mm front fan (Blue LED),
One 120x120x25 mm rear fan (exhaust)),
Support up to 9 x 120 mm fans :
Front fan x 3,top fan x 1, rear fan x 1,side fan x 4,
(side fan tray can be installed with 140 mm fan),
Retailing liquid holes
Expansion Slots
I/O Panel
Dual I/O Panel in the front and top USB 2.0 x 4, IEEE 1394 x 1, MIC x 1, SPK x 1(Support HD Audio)
Power Supply
Standard ATX PS2 / EPS 12V (optional)
UPC Code
884102001635
Micro fiber case cover
MSRP: $999.99
THANKS SO MUCH -
Maria
Description:
Custom Paint
Wax-able top coat
Screw-less slots
Superior Airflow
Innovative Style
Detail Spec
Available Color
30" x 28.4" x 17.4"
M/B Type
E-ATX, ATX, m-ATX,
Material
Aluminum : 1.0 mm
Weight
3.5" Drive Bay
5.25" Drive Bay
9 (Exposed)
Cooling System
Expansion Slots
I/O Panel
Power Supply
UPC Code
884102001635
MSRP: $999.99
+1 on to adding pix
ck1109
10-15-2015 11:06 PM
stevo4756
10-09-2015 01:54 AM
