g37x brake upgrade help
Hey everyone I recently bought a 2012 G37x with 36k miles on it, and I feel like one of the rotors is warped because when I make a more aggressive stop or anything above 40 my steering wheel shakes and at first it wasnt so noticeable but now I feel it a lot more. Im asked my dealer and they said to replace just the front rotors and pads would be around $650. Now Id rather buy the pads and rotors and do it on my own.
I was looking at StopTech drilled and slotted kit. Im assuming these will fit, however I wanted some feedback on whether or not to get these and any other brakes that you would recommend.
BTW I tend to speed and make quick stops a lot...
Also if I were to bump my budget to $1200 and get a set of performance brakes would you recommend that ?
Sorry for the long thread Im just picky when it comes to my car. Thanks
I'll try that today and see if it gets better. However in the case it doesn't And based off of your recommendation I found these on kns. And I should've clarified I have a sedan. Your thoughts ? Thanks btw
Each brake pad manufacturer has procedures to properly transfer new brake pad material on to the new raw rotor. Most low dust, low bite pads are good-to-go out of the box. Performance pads w/ better bite (and more dust) require bed-in of the pads to get the pad material evenly distributed on the fresh rotor. Here's a couple good link at Stoptech, one is the "warped rotor myth" and one is the bed-in process for their Street Pads. -Warped- Brake Disc and Other Myths ****Stock Brake System Bed-in
blnewt (10-22-2016)
