A/C problem and I need your help!
UPDATE: A/C problem and I need your help!
Okay, so I'm brand new to the forums. My car is a 2008 G37S Coupe and my A/C stopped blowing cold a few days ago and I'm looking for the A/C compressor fuse/relay so that I can rule that in/out before taking it in and overpaying at the shop. I checked all of the fuse boxes I can find, but no luck. Is there a fuse index/map available somewhere for my car? Any help is greatly appreciated
All right, so the clutch for my compressor is broken/won't catch and it's not an electrical problem so it needs replacing. So here's my question, should I just replace the compressor and clutch or should I attempt to just change the clutch? Are there certain car part websites that are better to search Infiniti parts from, or should I try and order one from an Infiniti/Nissan dealer? Again, thanks in advance for your help!
After changing the clutch and attempting to turn my A/C on, noticed a terrible noise that turned out to be a seized up compressor (which was undoubtedly the reason why the clutch was absolutely shot). Does anyone happen to know of a DIY a/c compressor replacement video that I could refer to before taking this on?
Envee
03-30-2016 10:28 PM
