URGENT! How to connect wires from exterior to interior fuse box?
H.E.L.P!!!!!!!
I want to install LED chassis lights for 2009 Nissan Skyline 370GT, but don't know where is the hole that wires can go through from exterior to interior fuse box(by the accelerator). Cheers!
Black Betty (02-16-2016)
so do I need to take the battery off? Thanks!
No, remove the cover over the battery and you'll see what you're dealing with.
You will have to remove the glove box to route the wires into the cabin, haven't seen this video but should give you an idea of what's involved, and while you're in there you might as well change your cabin air filter if it's been 20k miles.
Cabin air filter replacement- Infiniti G37 - YouTube
Thank you so much for the helps!
I'm sure there's a couple places where you could go through the firewall on the drivers side, the path I took seemed the easiest though.
When running the wires through the bulkhead and behind that center cluster I tape the wires to a harder steel wire, makes threading it through tight places much easier.
My DRLs are routed along the passenger side, w/ a relay then going through that rubber bulkhead into the cabin, then routed behind the carpet above the footwells and behind that center console. If you shine a light on the drivers footwell you can see from the passenger side where you can run your wires back there.
Not sure if the Skyline 370 would be the same, here's for the Sedan
Index of /FSM/G37/Sedan
And coupe
Index of /FSM/G37/Coupe
01-30-2016 05:25 PM
