Looking for a G, but notice rust on brake caliper. Should I worry?
Old 06-02-2014 | 03:17 PM
SunnyG's Avatar
SunnyG
Over the weekend I went to check out this 2008 G35X. However, I notice there are rust on the rear brake calipers (both sides). Funny, I didn't notice any rust on the front ones. Should I worry?
Old 06-02-2014 | 05:09 PM
Nothing to worry about really, the base calipers only have a light coating over the cast iron so it's common. I would give a good check underneath in places that should be better protected and look for any rust on any body panels.
SunnyG (06-02-2014)
Old 06-03-2014 | 08:10 AM
Paratrooper's Avatar
Paratrooper
Scotch pad and fresh paint is you need there. All 4 of mine had surface rust.
SunnyG (06-03-2014)
Old 06-03-2014 | 10:10 PM
USMC93V's Avatar
USMC93V
Cast iron will rust if you take notice to most cars you will see rust around the edges and the hub. This rust will also act as a protector not as pretty if you were to metal wheel brush off prime and paint but totally normal. Most rotors are replaced well before this would cause a problem.
Old 06-04-2014 | 10:14 AM
guy from norcal's Avatar
guy from norcal
yeah, i get rust on my rotors every time i wash the car.
drewfinity
09-24-2015 11:01 AM
Simran Mann
09-09-2015 02:08 AM
slawek65
09-08-2015 09:07 AM
ZachThomas
09-03-2015 01:40 PM
Quick Reply: Looking for a G, but notice rust on brake caliper. Should I worry?
