Cheap Eibach Spacers!
Auto Accessories & Aftermarket Parts at AutoAnything | Truck Accessories & Car Accessories | Floor Mats, Tonneau Covers & Car Covers
use the vehicle as a 2008 350z and search wheel spacers. It pulls up the Eibachs. The system 4 are the nut style and the ones I went with. They pull up as around $110 a pair. Enter coupon code LOYALTY on the check out screen. Free shipping + 15% off... DEAL! (I think the order must be over $150 before the discount is applied. I may be wrong though.)
Thanks WLMNGTN
Thanks WLMNGTN
No need for out side link. Jeb Performance can beat that price. However I have to let members know. Eibach does not make spacers for the G37. They are for 370Z with -1mm on hub. Always use vehicle specific parts. Especially for spacers.
Edit: Jeb. I searched around found the H&R spacers you sell are 66.2 and for the G37, but then there are also plenty that are 66.1. I also cannot find a definite answer online as some people say 66.1mm, but some say 66.2.
Wouldn't the tighter fit of a 66.1mm CB be more beneficiary as .1mm more would be just a little more loose?
I am not trying to go toe to toe with you as I am sure you know twice as much as I do about these spacers, but just reporting my findings. I guess if nothing else I will report back after I put them on.
I did not want to have to swap out my wheel studs. The specs are 5x114.3 CB 66.1 which is the same as the G37.
0.01 mm on spacers which have diameter of 7" wobbling 0.01 mm. Transfered to your tires which are +- 25" diameter. is going to be considerable amount of wobble.
Plus Auto Anything offers DRS system only which are extended studs stystem which extends from your hub to lugz. A cheaper model offered from Eibach for 370Z.
So it is reasonable price for 370Z DRS system spacers. However not a spectacular deal. Also I strongly do not recommend use on our G's.
NO
the link to these spacers is here.
2008 Nissan 350Z Eibach Wheel Spacers, Eibach Spacers, Wheel Spacer you can clearly see the prices are cheaper already and then with the 15% off its even more.
Do you have any official spec that the center bore is 66.2mm? I called my dealer and the guy is getting back to me, but said he thinks it is 66.06mm.
No. I am telling you I got the system 4, not the extended stud, for 195.42. You may assume there will be wobble, but several members have told me they have had zero problems.
H&R test fits on our G. Does numerous R&D. Gets all the paper work for liability issues. Get them approved. I think H&R deserves $100 for all the work they have done on our car.
Fitting right parts in a long run will save us money. Less Hassle and peace of mind.
So I ask our G owners not to gamble $100, and risk millions at stake.
Well in my opinion it's a great deal, and I do not see where the risk is going to come from. Other automotive websites list these for the G37. They are a CB of 66.1mm which is the factory specification of this vehicle. Not knocking the H&R Spacers, but they are 66.2mm which is .1mm bigger than the specification calls for. I've only heard good things about the H&R Springs and JEBPerformance, and I'm sure you have a much better overall customer experience. The only reason I didn't buy the H&Rs is because they are the extended stud kind. I will try out my spacers. If they are not what I like you will see them up for sale and I will pick up some H&Rs from you.
