19 in wheel weight
Moderador
19 in wheel weight
I would like to compile a list of OEM wheel weights in search for the "best width/weight OEM wheel"
Though there is some old info in multiple places, most are either all text or random pictures.
Feel free to chime in with your own contribution of OEM infiniti/Nissan 19" 5x114.5 wheel.
Looking to see if I can find more Infiniti SUV wheels and track spec nissan 19s
370z Sport Rays
19x9 Front: Rim 23.2lbs With tire/stock 52.2lbs
19x10 Rear: Rim 23.9lbs with tire/stock 56.8lbs
370z Base
Front Wheels (Sport Package): 23.2lbs(10.52kg)
Rear Wheels (Sport Package): 23.8lbs (10.8kg)
370Z NISMO S-tune
Rays, Front 19"x9" +47, 20.5 lb
Rays, Rear 19"x10" +30, 20.9 lb
370Z NISMO 2015-2017
Rays, Front 19"x9.5" +40, OE P/N D0C003GM3A, 21 lb
Rays, Rear 19"x10" +23, OE P/N D0C003GM3B, 23 lb
370Z NISMO 2009-2012
Rays, Front 19"x9.5" +47, OE P/N D0C001A34A (Hyper Silver), weight ?
Rays, Rear 19"x10.5" +30, OE P/N D03001A34B (Hyper Silver), ~23 lb
G37/Q60 S coupe/Convo
19x 8.5 15 spoke 27 lbs
G35 coupe Rays
19lbs. front and 21lbs. rear.
A34 Nismo wheels. 19x8.5 square, 35mm offset, and ~19-20lbs. I do like the 15+ Nismos but to fit correctly imo you need to run a set of 4 front wheels.
Nismo LMGT4
19"X8.5" +25 offset (Front) Weigh 20.5 lbs (8.2 kg)
19"X9.5" +30 offset (Rear) Weigh 20.9 lbs (8.5kg)
source: https://my350z.com/forum/wheels-and-...ml#post5757189
18"X8.5" +25 offset (Front) Weigh 18.1 lbs
18"X9.5" +30 offset (Rear) Weigh 19.0 lbs
370z Sport Rays
370z Base
370Z NISMO S-tune
G35 coupe Rays
Nismo LMGT4
Great idea. Something BB tried to get going 12 years ago: https://www.myg37.com/forums/wheels-...reference.html
I believe the staggered, 18" Sport Wheels from the Sedan were 23.4 and 25.2 pounds respectively front to rear.
And the OEM Bridgestone RE050A tires were 27 and 28 pounds, which were kind of heavy tires.
Moderador
That was the idea behind this, there's info everywhere but it's lacking pictures and these are important.
Other than the first gen Rays only Nismo wheels seem to be the best contenders
My favorite option for the G sedan is the A34 Nismo wheels. 19x8.5 square, 35mm offset, and ~19-20lbs. I do like the 15+ Nismos but to fit correctly imo you need to run a set of 4 front wheels.
Rochester (11-01-2021)
Image is from Iilac's car
Nismo LMGT4
(I have these and can weight to confirm)
source: https://www.proracing.cz/fotky12573/...ght-weight.pdf
Moderador
Nismo LMGT4
I've edited my original post to reflect them.
Picked up a set of Q50 Performance Package Rays, same as 370z 19x9 fronts. Weighed them on a bathroom scale at 23.8lbs. I'll most likely be replacing my coupe 19s with these. Don't mind all the dirt, I didn't have a chance to clean them up.
backman_66
05-31-2023 06:12 PM
Status Elite
Picture Share G Coupe
09-18-2009 04:46 PM
