stock G37 6MT 13.48 @ 105.8
#62
the only way i got this to work is by VERY slightly lifting up the gas from the floored position.. car jerks forward, so it seems right. but ya, i found it impossible to do this with the pedal completely floored the whole time
#63
just tried that powershift multiple times with 3rd to 4th gear. i dont push the clutch all the way in, just to the engagement point. i know i hit it cause the gear pops out of 3rd real easily, but it just wont go into 4th no matter how fast i do it when i leave the pedal floored.
#64
It's not you. It's hard to do correctly all the time. just be careful with your clutch.
#65
Careful on your clutch That's the least your worries. You should be more worried about the syncros and dog gears. Mess up a shift and you could easily wreck them. Even perfectly executed powershifts will put a lot of stress on these components. The clutch really doesn't care assuming you do it right. Heck, if your good, you can actually shift without a clutch. I use to do it all the time in my old CRX and on occasion in my Maxima.
#66
Are you Dave B the Nissan parts guy???
#67
No change in tire pressure. Ran at 85' weather. I had a bad launch.
I'll be at the strip this sunday, I'll have vids and pics posted by then
