Track Stars of MyG37
<img src=https://www.myg37.com/forums/attachment.php?attachmentid=76098&d=1191641062 >
If you like numbers, just for the fun of it, here’s a quick summary index of the runs from our future hall-of-famers.
1) First up is Heat, looking good in a stock Graphite G barely past break-in, maybe not quite optimal engine output yet.
2) Next is Ahujadaddy in an Athens Blue already at 3000 miles, also stock.
3) This just in, KAHBOOM in a stock OB with new best time for the G under cooler conditions and under 13.8!
4) Long awaited first 6MT, EJ2000 launches using clutch skillz in a loaded stock G (OB of course) with 4WAS under slick conditions.
5) First outing by rookie spyderbret at The Strip, quite possible the thinner air hurts a heavy G
6) Second outing by spyderbret, odo now at 5800 miles
7) A great 13.571 run by FLGspot in his lightly modded G!
Don’t miss out on the great après-race commentaries, pics/vids, advice, and tips shared. With enough experience gained running the G37, the prediction is 13.7 1/4 mile is possible for a stock G37.
Good luck on the next runs!
Driver and Car Bio:
Heat
2008 G37S 5AT AG/G
Break-in method: hard (oil changed: 700 miles)
Run Details:
Mileage: 1000 miles
Launch method:
VDC Off
Shift mode: DS
Weight: ¾ tank full
Mods: stock
Track conditions: rained 2 hours earlier
Best Run Numbers:
R/T ... 0.307
60' ... 2.237
330 ... 6.148
1/8 ... 9.321
MPH ... 76.80
1000 ... 12.034
1/4 ... 14.305
MPH ... 99.62
Driver and Fan Commentaries (full details):
https://www.myg37.com/forums/g37-coupe/174473-5at-real-track-times-better-than-mags.html
Driver and Car Bio:
Ahujadaddy
2008 G37S 5AT AB/G
Run Details:
Mileage: 3000 miles
Launch method: brake torque 1800-2400rpm
VDC Off
Shift mode: DS
Weight: full tank
Mods: stock
Track conditions: dry, 80°F
Capital Raceway, Crofton
Best Run Numbers:
R/T ... 0.295
60' ... 2.187
330 ... 5.968
1/8 ... 9.071
MPH ... 79.26
1000 ... 11.725
1/4 ... 13.956
MPH ... 101.64
https://www.myg37.com/forums/motorsports-track/174515-video-and-time-slips-of-my-g37-at-the-1-4-mile-track-broke-14-0-a.html
https://www.myg37.com/forums/video-share/174516-stock-g37-at-the-track-video-inside.html
http://www.youtube.com/watch?v=xxt8iNMlQZg (G37 vs 07 G35S video)
Driver and Car Bio:
KAHBOOM
2008 G37S 5AT OB/G
Break-in method: factory recommendation
Run Details:
Mileage: just under 1200 miles (almost final break-in)
Launch method: pedal mash (very little wheel spin)
VDC off
Shift mode: manual (1-2 a little past redline)
Weight: shy of 30 miles of gas left
Mods: stock
Track conditions: 53.6°F
Best Run Numbers:
R/T ... 0.242
60' ... 2.026
330 ... 5.897
1/8 ... 8.948
MPH ... 81.41
1000 ... 11.575
1/4 ... 13.798
MPH ... 103.06
https://www.myg37.com/forums/motorsports-track/174961-stock-1-4-mile-5at-run.html
Driver and Car Bio:
EJ2000
2008 G37S 6MT OB/G loaded with 4WAS
Break-in method: calculated hard
Run Details:
Launch method: 3500rpm feathered clutch for traction
VDC off
Shift mode: manual
Weight: heavy
Mods: stock
Track conditions: 60°F, low humidity, 5-10mph head/cross wind, slightly slick (not ideal for low 60')
Best Run Numbers:
R/T ... 0.168
60' ... 2.130
330 ... 5.975
1/8 ... 9.088
MPH ... 79.53
1000 ... 11.727
1/4 ... 13.956
MPH ... 101.20
https://www.myg37.com/forums/motorsports-track/175147-1st-6mt-at-the-track.html
Driver and Car Bio:
spyderbret
2008 G37S 5AT LP/G Premium Nav
Break-in method:
Run Details:
Mileage: 1300 miles
Launch method: brake torque 2000rpm
VDC ?
Shift mode:
Weight: heavy
Mods: stock
Track conditions: 70°F
The Strip at LVMS (high elevation at 1950 feet above sea level)
Best Run Numbers:
R/T ... 0.516
60' ... 2.385
330 ... 6.517
1/8 ... 9.840
MPH ... 74.19
1000 ... 12.695
1/4 ... 15.073
MPH ... 95.47
https://www.myg37.com/forums/motorsports-track/177111-ran-the-1-4-mile-last-night.html
Driver and Car Bio:
spyderbret
Break-in method:
Run Details:
Mileage: 5800 miles
Launch method: brake torque just under 1000rpm
VDC off
Shift mode: DS
Weight: heavy
Mods: stock
Track conditions: 50°F
Best Run Numbers:
R/T ... 0.305
60' ... 2.302
330 ... 6.157
1/8 ... 9.317
MPH ... 77.54
1000 ... 12.038
1/4 ... 14.314 (elevation adjusted 13.95)
MPH ... 99.16 (elevation adjusted 101.83)
https://www.myg37.com/forums/showthread.php?t=177111
Driver and Car Bio:
FLGspot
2008 G37
Break-in method:
Run Details:
Launch method:
VDC ?
Shift mode:
Weight:
Mods: fujita intake, FI exhaust and HFC's
Track conditions:
Best Run Numbers:
R/T ... 0.142
60' ... 2.073
330 ... 5.819
1/8 ... 8.829
MPH ... 81.49
1000 ... 11.406
1/4 ... 13.571
MPH ... 103.51
https://www.myg37.com/forums/motorsports-track/178309-ran-1-4-mile-last-night.html
Driver and Car Bio:
Heat
2008 G37S 5AT AG/G
Run Details:
Mileage: 1000 miles
Launch method:
VDC Off
Shift mode: DS
Weight: ¾ tank full
Mods: stock
Best Run Numbers:
R/T ... 0.307
60' ... 2.237
330 ... 6.148
1/8 ... 9.321
MPH ... 76.80
1000 ... 12.034
1/4 ... 14.305
MPH ... 99.62
Driver and Car Bio:
Ahujadaddy
2008 G37S 5AT AB/G
Run Details:
Mileage: 3000 miles
VDC Off
Shift mode: DS
Weight: full tank
Mods: stock
Best Run Numbers:
R/T ... 0.295
60' ... 2.187
330 ... 5.968
1/8 ... 9.071
MPH ... 79.26
1000 ... 11.725
1/4 ... 13.956
MPH ... 101.64
Driver and Car Bio:
KAHBOOM
2008 G37S 5AT OB/G
Run Details:
VDC off
Mods: stock
Best Run Numbers:
R/T ... 0.242
60' ... 2.026
330 ... 5.897
1/8 ... 8.948
MPH ... 81.41
1000 ... 11.575
1/4 ... 13.798
MPH ... 103.06
Driver and Car Bio:
EJ2000
Run Details:
VDC off
Shift mode: manual
Weight: heavy
Mods: stock
Best Run Numbers:
R/T ... 0.168
60' ... 2.130
330 ... 5.975
1/8 ... 9.088
MPH ... 79.53
1000 ... 11.727
1/4 ... 13.956
MPH ... 101.20
Driver and Car Bio:
spyderbret
Break-in method:
Run Details:
Mileage: 1300 miles
VDC ?
Shift mode:
Weight: heavy
Mods: stock
Best Run Numbers:
R/T ... 0.516
60' ... 2.385
330 ... 6.517
1/8 ... 9.840
MPH ... 74.19
1000 ... 12.695
1/4 ... 15.073
MPH ... 95.47
Driver and Car Bio:
spyderbret
Break-in method:
Run Details:
Mileage: 5800 miles
VDC off
Shift mode: DS
Weight: heavy
Mods: stock
Best Run Numbers:
R/T ... 0.305
60' ... 2.302
330 ... 6.157
1/8 ... 9.317
MPH ... 77.54
1000 ... 12.038
Driver and Car Bio:
FLGspot
2008 G37
Break-in method:
Run Details:
Launch method:
VDC ?
Shift mode:
Weight:
Track conditions:
Best Run Numbers:
R/T ... 0.142
60' ... 2.073
330 ... 5.819
1/8 ... 8.829
MPH ... 81.49
1000 ... 11.406
1/4 ... 13.571
MPH ... 103.51
Last edited by SilkeG; 03-01-2008 at 06:47 PM. Reason: Added spyderbret and FLGspot
hahahha, AWESOME! I really thought i'd be the first to track it, but the other dude beat me by a couple days.
btw, i had a "full tank of unleaded" lol... but yea, full tank for me. Tryin to keep stuff constant for now, bfr i go for a REALLY fast time... at which time i will remove the spare tire also.
Track conditions were: Dry and bout 80 degrees
OT: Have you guys seen the donut. That is one nice *** donut we have.
KAHBOOM, WOW!!! I knew there was hope for us. That is a very good time and the engine is still not completely broken in. WOOT WOOT!! I must brag your time to some friends.
If you can shift as fast..
That's awesome tho that you got the time that you did kahboom. Hey, I think I'm going back to the G again... And save me about 35k to invest My mom will have the SUV, so I'll just use hers to lug people around in
stevo4756
10-09-2015 01:54 AM
KZK
Canada
09-24-2015 12:09 AM
KZK
Canada
09-23-2015 11:52 PM
