High Performance Mass Air Flow Sensor
i recently discovered that jet performance released a mass air flow sensor for our g37 it claims to increase air by 45 percent anybody think this is bull?
JET Performance Products, Import & Domestic Performance, Performance Kits, Fuel Systems, Transmissions
So if you replace the MAF sensors on both sides with these JET ones you're looking at a 90% airflow increase!!
I can't believe people waste their money on 5 figure turbo builds.
saparda (10-15-2013)
Well, that's swell, but if your not trying to push 45% more air through the engine, the extra flow capacity is kind of wasted. I would think this is intended more for forced induction where your pushing more air though the engine than it would normally suck via the pistons and swept volume of the six cylinders. Unless Infiniti under spec'd the sensor, the stock version is all a stock engine needs. So whether its bull or not seems a bit immaterial for most G owners on the road.
abrecos (08-29-2019)
SuicidalG37SGuy
09-10-2015 06:01 AM
