Help Installing LED Interior Lights
Does anyone have a tutorial on how to install LED lights in a 08 Coupe? I'm having trouble locating the fuse panel. I'd like these lights to allow me to control when to turn on /off ( i already have a switch). The instructions that it comes with don't help much.
Huh, it's easy what fuse bs u saying? Lol pop out the lens with a flathead pull out the bulb and pop in the led wire, then stick the LEDs up there and bam! 5 min done, I just did mine
run it to a switch and straight to the battery. its clean. if you want to control it with other lights, use a relay to use a stock on/off switch.
If you're talking about LED's by your legs and random lights around the car,....then my instructions are to walk over the trash, throw them as hard as you can on the bottom so they shatter, and walk away slowly so no one notices that you're trying to hide something that could be so full of Rice.
Cheers!
Cheers!
superjoey
31
03-22-2023 11:56 PM
maybeg37
09-08-2015 02:33 PM
