Radiator cover removal
Old 10-05-2010 | 02:18 PM
indyn's Avatar
indyn
Does the sport model have extra plastic clips as indicated in the pic as compared to non-sport on the radiator cover.
I'm trying to remove this cover to install a stillen gen 3 and took out all the clips and screws as indicated by the red circle but doesn't want to come out. There are still three clips holding as marked with white squares but none of the DIYs or service manual advise to remove these.
pic, courtesy of stillBalling37
Old 10-05-2010 | 02:50 PM
ucla bruin's Avatar
ucla bruin
That is correct, you only need to remove the red circles. It doesn't come out easily because I think you need to push the cover towards the back of the car a little bit then up to make it come out.
__________________
Old 10-05-2010 | 03:26 PM
indyn's Avatar
indyn
will try as you've suggested, but it still feels like something is holding it down.
Old 10-05-2010 | 03:30 PM
g37mobbin's Avatar
g37mobbin
^yeah, it is a small clip in the back that ucla bruin says.
Old 10-05-2010 | 05:35 PM
hispeed-lowdrag's Avatar
hispeed-lowdrag
Yeah if you look on the back of it (the part that runs vertically) there are two holes with plastic pieces running into them, you need to push the cover from the front to the back and make it slide back to undo those
Old 10-06-2010 | 01:09 PM
indyn's Avatar
indyn
I did get it out but I had to take out the three plastic clips as marked in white in the pic.
philttz
09-21-2015 11:12 AM
pal51961
09-20-2015 08:42 PM
CasperG37
09-14-2015 07:46 PM
OldG37
09-06-2015 10:38 PM
Quick Reply: Radiator cover removal
