Help air intake question
air intake question
hey guys! im looking to buy a intake for my G but ive heard from someone that for some intakes that you might need to cut parts of your engine or something.. i dont know much about intakes or even modding
so does anyone know if this is true? if so which intakes are out there that doesnt require parts being cut?
-Jo Kadosh
-Jo Kadosh
-Jo Kadosh
-Jo Kadosh
The Stillen Gen 3 CAI (cold air intake) requires some minor cutting of the holes that the tubes need to run through--it will be through the holes that the lower air ducts from the stock airbox go through. The holes can be cut easily with a dremel type rotary tool. The Stillen Gen 3 intake filters will sit behind the front grill. The Injen CAI requires removal and replacement of the washer fluid tank and sits down inside the lower bumper. Both CAIs are installed typically by removing the front bumper.
Short ram intakes can be installed without removing the front bumper.
To install aftermarket intakes, the stock airboxes are removed.
If you are concerned about removing your front bumper and cutting away or relocating your washer fluid tank. Simply go with an SRI (Short Ram Intake), no cutting, I have one and I am more than pleased with it. Installs in less time and looks great too.
Well you already picked it up so its kinda too late for what we think. Question is, what do you think?
R2C is the only company making the whole system, intake and filter and they specialize in filter design. If you look at my Access Port captures you'll see their CAI design does indeed intake cool air while the cars in motion. The Takeda would have been my second choice, negs are minimal heat shielding and unknown filter quality. As far as filter, without a direct test between R2C's and Takeda's in terms of performance throughout the dust loading curve your guess is good as mine but I'd bet it's a decent setup and worth the bucks. Check your Air/Fuel ratio before and after installation to judge impact. Unless it leans out a bit which is doubtful since it's probably not as free flowing as cotton guaze you'll want to also do an exhaust and a tune to really maximize performance. On a good day with these three you'd be doing good if you can pull 25+ HP. Lot of bucks for an intake, exhuast and tune for such small gains but then you definately won't want to go back after feeling it and the sound is pure music and a primary motivator that makes it worth it as well IMO.
superjoey
31
03-22-2023 11:56 PM
Simran Mann
09-13-2015 01:51 AM
