G Sedan doing some driftin in Oman
It does have a VLSD. GCC spec G's come as 7AT/5AT + VLSD standard. They don't come with 6MT or non-VLSD.
Is that Abo Feghali driving the G37? cause it's pretty difficult doing those tight turns without a handbrake unless you're a pro.
Here's a quick vid from yesterday in my 5AT G sedan
08 Infiniti G35 sedan drift 2 - YouTube
There are three different brake options for the 2nd gen G.
From worst to best:
2 piston front / 1 piston rear
These are the lowest end brakes. They use the smallest rotors and come on the base model and Journey sedans.
1 piston front / 1 piston rear
These use the same rear setup as the above brakes but the front brakes use a larger single piston with a larger diameter rotor. These came with the Sport and 6MT options for the sedan. They also come standard on all GCC spec G35/G37 sedans from 2007-2012. These are the brakes used on the base model 370z and G37 coupe and any non-S models.
4 piston front / 2 piston rear (Akebono)
Standard brakes on all GCC spec 370z's and G37's. Never used on G37 sedans in the GCC. In the US, these replaced the above brake option for sedans with the Sport package (or 6MT) starting from 2009. Sport sedan wheels were changed 09+ to accommodate the larger calipers. Since these never made it to the GCC on the sedans, the sedan uses the exact same wheels from 2007-2012 in the GCC.
From worst to best:
Tunerz_Store
Brakes/Suspension
117
07-16-2018 03:04 PM
aktif8
05-23-2016 12:56 PM
johnadlertech
09-14-2015 01:22 PM
johnadlertech
09-14-2015 01:18 PM
m3clubracer
09-13-2015 10:01 AM
