FS: LED Front Turn Signals for Coupe and Sedan!
Infiniti G37 Front Turn Signal Bulbs
7440 27-5050 SMD LED Bulb is a direct replacement for any 7440-size turn signal bulb. This bulb has 27 5050-size SMDs. It uses an 7440-size terminal and will fit as a replacement for stock halogen. It uses less power and heat than halogen bulbs, and will last longer, with its engineered heat-sinking technology. A load resistor is embedded to prevent blowing the LED from voltage surge, and a diode is implanted to protect the LED from reverse polarity. The LED is wired for 12v operation, the kind found on all vehicles.
The advantage of LED turn signals, when compared to your stock bulbs, is that these are instant-on and -off, for a very crisp, modern look. These are a nice, true, amber turn signal, with that modern look of LED!
Resistor Option: The Infiniti G37 will have fast-blinking when LED bulbs are installed as turn signal replacements. We offer resistors to remedy this issue for a nominal charge.
We carry the brightest, highest-quality bulbs at the lowest prices. Your order will ship same day, and we're here if you need us for support and service. And we do not jack up the prices to astronomical levels- We're breaking that market trend, and offering you great, low prices, every day. These LED bulbs are made just for us by a company that has been in business since 1992, and every bulb carries with it a one-year full warranty.
Click to learn more
Click to learn more
Thanks!
Paul
So it will hyperblink if you install these without resistors then?
Bulbs are $39.99, and shipping is just $5 for any order. So $44.99 total. If you'd like to add resistors to slow down hyperblinking, it would be $54.99 total. Thanks!
Is the resistor in the bulb or is it another external source? Also I just installed newer headlight bulbs and I see where the turn signal bulbs are on my 2012 sedan, but it looked like a paint to get to, anyone done this yet?
Also, do u make them in hyper white like your other bulbs?
Hey DD, need some help. You guys just shipped me some SwitchBack bulbs for my 2012 G37 Sedan. The receipt and email you referenced were the "7443 Switchback 60-1210 SMD (pair)". I went to install them and the LED light is too big to fit into the headlight turn signal housing.
Was this the wrong bulb for my car, or did 2012 change the housing a bit and I'm the first guy to try it? I'm hoping to get some help so I can get the right bulbs, Thank you very much.
