Special New FREE Car Care Product every week at DetailedImage.com
Old 06-12-2013 | 09:14 AM
  #121
Detailed Image's Avatar
Detailed Image
Auto Detailing Expert
This week's Weekly Special is Einszett Gummi Pflege Stift Rubber Care Stick - 100 ml.
Use Coupon Code WSGUMMI2413 to receive it for Free. A $8.99 value! Min spend $45. Offer ends 6/18/13 at 11:59 PM EST.
  • Restore and care for rubber trim and seals to keep them elastic and looking like new
  • Protects against extreme temperature and UV rays
  • Shoe polish like applicator makes the application extremely easy and smooth
Old 06-19-2013 | 09:26 AM
  #122
Detailed Image
This week's Weekly Special is Stoner Invisible Glass - 19 oz.
Use Coupon Code WSINVIS2513 to receive it for Free. A $5.99 value! Min spend $30. Offer ends 6/25/13 at 11:59 PM EST.
  • Foam based glass cleaning formula that is ammonia free, making it safe on tinted windows
  • Easily removes oily dirt, dust, fingerprints, grease, adhesives, smudges, smoke haze and more from glass
  • Best applied with an all purpose microfiber towel, then wiped clean with a dry low nap microfiber towel
  • Do not apply in direct sunlight or hot glass, otherwise streaking may occur
Old 06-26-2013 | 09:17 AM
  #123
Detailed Image
This week's Weekly Special is Dodo Juice Hard Candy Hard Wax - 30 ml.
Use Coupon Code WSHARDC2613 to receive it for Free. A $9.99 value! Min spend $55. Offer ends 7/2/13 at 11:59 PM EST.
  • A Dodo Juice hard carnauba wax designed to work on any colored vehicle, light or dark
  • Extremely easy to apply and remove, especially when applied in thin layers
  • Strong protection and tight water beading makes maintaining your vehicle a breeze afterwards
  • Dodo Juice hard waxes offer slightly more durability than the Dodo Juice soft waxes
  • Apply with a foam applicator pad and remove with a plush microfiber towel
Old 07-03-2013 | 05:04 PM
  #124
Detailed Image
This week's Weekly Special is P21S Gel Wheel Cleaner - 500ml Kit.
Use Coupon Code WSGELWH2713 to receive it for Free. A $17.99 value! Min spend $75. Offer ends 7/9/13 at 11:59 PM EST.
  • One of the safest, most effective, pH balanced wheel cleaners on the market
  • Gel based formula allows the product to penetrate vertical surfaces for a more effective cleaning
  • Perfect option for after market wheels as it is safe for virtually any wheel surface
  • Works best when an E-Z Detail Brush is used in conjunction with P21S Gel Wheel Cleaner
  • Follow up with Poorboy's World Wheel Sealant for wheels that are easier to maintain
Old 07-10-2013 | 10:30 AM
  #125
Detailed Image
This week's Weekly Special is 3M Automotive Masking Tape - 18 mm.
Use Coupon Code WSAUTOM2813 to receive it for Free. A $2.99 value! Min spend $25. Offer ends 7/16/13 at 11:59 PM EST.
  • Quality masking tape for protecting your trim, paint and more!
  • Instantly sticks on surfaces and releases quickly and cleanly without residue left behind
  • Great value!
Old 07-24-2013 | 09:43 AM
  #126
Detailed Image
This week's Weekly Special is P21S Total Auto Wash - 1000 ml Kit.
Use Coupon Code WSTOTAL3013 to receive it for Free. A $17.99 value! Min spend $95. Offer ends 7/30/13 at 11:59 PM EST.
  • One of the most versatile products we offer, degrease nearly any surface safely and effectively
  • Use on paint, trim, rubber, vinyl, carpets, plastic, glass, leather and many other surfaces
  • Can be used at full strength or diluted down to clean more delicate surfaces
  • Used by many high end detailers to properly prep surfaces for polishing, restoring or protecting
  • A must have any detailing enthusiasts or pro detailers arsenal of products
Old 07-31-2013 | 09:36 AM
  #127
Detailed Image
This week's Weekly Special is P21S Gel Wheel Cleaner - 1000 ml.
Use Coupon Code WSGELWH3113 to receive it for Free. A $22.99 value! Min spend $120. Offer ends 8/6/13 at 11:59 PM EST.
Old 08-07-2013 | 09:31 AM
  #128
Detailed Image
This week's Weekly Special is Einszett ColourTec Wheel Cleaner - 16.9 oz.
Use Coupon Code WSCOLOU3213 to receive it for Free. A $13.99 value! Min spend $45. Offer ends 8/13/13 at 11:59 PM EST.
  • Extra strong and effective wheel cleaner that is very gentle and non-corrosive
  • Safe on chrome, alloy, anodized, stainless steel, clear coat and polished wheels
  • This product changes colors after it breaks down select contaminants
  • A premium wheel cleaner professionals and enthusiasts will absolutely love
Old 08-14-2013 | 09:23 AM
  #129
Detailed Image
This week's Weekly Special is Scotchgard Auto Fabric & Carpet Foaming Cleaner - 17.5 oz.
Use Coupon Code WSAUTOF3313 to receive it for Free. A $5.89 value! Min spend $35. Offer ends 8/20/13 at 11:59 PM EST.
  • Deep clean and protect your carpets in one easy to use foam cleaner!
  • Penetrates into carpet and upholstery fibers, breaking up dirt and lifting out stains
  • Will restore that brand new look to your fabric, carpets, and floor mats
Old 08-21-2013 | 09:19 AM
  #130
Detailed Image
Use Coupon Code WSTOTAL3413 to receive it for Free. A $17.99 value! Min spend $75. Offer ends 8/27/13 at 11:59 PM EST.
Old 08-28-2013 | 09:31 AM
  #131
Detailed Image
This week's Weekly Special is Dodo Juice Banana Armour Hard Wax - 30 ml.
Use Coupon Code WSBANAN3513 to receive it for Free. A $9.99 value! Min spend $45. Offer ends 9/3/13 at 11:59 PM EST.
  • A Dodo Juice hard carnauba wax designed to work exceptionally well on warmer colored vehicles
Old 09-04-2013 | 09:35 AM
  #132
Detailed Image
This week's Weekly Special is Einszett Anti-Insekt Bug + Tar Remover - 500 ml.
Use Coupon Code WSANTII3613 to receive it for Free. A $9.99 value! Min spend $55. Offer ends 9/10/13 at 11:59 PM EST.
  • Paint safe pre-wash degreaser that effectively helps loosen stubborn contamination prior to washing
  • Avoid scrubbing to remove tar, bugs, etc. which will minimize adding swirls and scratches to your paint
  • Safe to use on head lights, chrome, glass, rubber, plastic and paint surfaces
Old 09-11-2013 | 09:30 AM
  #133
Detailed Image
This week's Weekly Special is Sonax Wheel Cleaner Full Effect - 500 ml.
Use Coupon Code WSWHEEL3713 to receive it for Free. A $15.99 value! Min spend $65. Offer ends 9/17/13 at 11:59 PM EST.
  • Sonax Wheel Cleaner 2 pack & Bonus Dashboard Cleaner ONLY $30!!!
  • Extra strong wheel cleaner that is very gentle and pH neutral
  • The 500ml bottle's spray nozzle provides a fine mist and steady stream which helps conserve product
  • A premium wheel cleaner professional detailers absolutely love
  • Sprays on fluorescent green and changes to a deep red as it reacts with contaminants on your wheel
Old 09-18-2013 | 09:15 AM
  #134
Detailed Image
This week's Weekly Special is DI Brushes Boar's Hair Detailing Brush - 1".
Use Coupon Code WSBOARS3813 to receive it for Free. A $15.99 value! Min spend $80. Offer ends 9/24/13 at 11:59 PM EST.
  • Use it to clean your wheels, exterior trim and so much of the interior
  • Ultra soft boar's hair fibers make it safe to use everywhere
  • Very durable design and fibers so you can use this brush for years
  • Helps clean tough to reach areas safely and easily
Old 09-25-2013 | 09:16 AM
  #135
Detailed Image
Use Coupon Code WSGELWH3913 to receive it for Free. A $17.99 value! Min spend $85. Offer ends 10/1/13 at 11:59 PM EST.
