Special New FREE Car Care Product every week at DetailedImage.com
Old 07-20-2011 | 02:04 PM
  #31
Detailed Image's Avatar
Detailed Image
Auto Detailing Expert
This week's Weekly Special is Einszett 1Z Cockpit Premium - 500 ml.
Use Coupon Code WSCOCKP2911 to receive it for Free. A $10.99 value! Min spend $70. Offer ends 7/26/11 at 11:59 PM EST.
  • One of the best interior cleaners and protectants that leaves your finish factory new
  • Easy to get streak free results every time, great scent, and UV protects
  • Best used on your dash, gauge cluster, navigation screens, audio components, shift *****, arm rests, leatherette, steering wheels and much more
Old 07-28-2011 | 09:17 AM
  #32
Detailed Image
This week's Weekly Special is DI Accessories Gentle Fine Grade Clay - 100 g.
Use Coupon Code WSGENTL3011 to receive it for Free. A $10.99 value! Min spend $40. Offer ends 8/2/11 at 11:59 PM EST.
  • Safely and effectively remove tar, sap, paint over spray and more
  • Fine grade clay bars will not mar your finish when used properly
  • We recommend using Dodo Juice Born Slippy as your clay lube
Old 08-03-2011 | 09:18 AM
  #33
Detailed Image
This week's Weekly Special is DI Brushes Boar's Hair Detailing Brush.
Use Coupon Code WSBOARS3111 to receive it for Free. A $15.99 value! Min spend $85. Offer ends 8/9/11 at 11:59 PM EST.
  • Use it to clean your wheels, exterior trim and so much of the interior
  • Ultra soft boar's hair fibers make it safe to use everywhere
  • Very durable design and fibers so you can use this brush for years
  • Helps clean tough to reach areas safely and easily
Old 08-10-2011 | 09:10 AM
  #34
Detailed Image
This week's Weekly Special is P21S Gel Wheel Cleaner - 1000 ml.
Use Coupon Code WSGELWH3211 to receive it for Free. A $22.99 value! Min spend $100. Offer ends 8/16/11 at 11:59 PM EST.
  • One of the safest, most effective, pH balanced wheel cleaners on the market
  • Gel based formula allows the product to penetrate vertical surfaces for a more effective cleaning
  • Perfect option for after market wheels as it is safe for virtually any wheel surface
  • Works best when an E-Z Detail Brush is used in conjunction with P21S Gel Wheel Cleaner
  • Follow up with Poorboy's World Wheel Sealant for wheels that are easier to maintain
Old 08-17-2011 | 09:16 AM
  #35
Detailed Image
This week's Weekly Special is Einszett 1Z Gummi Pflege Stift Rubber Care Stick .
Use Coupon Code WSGUMMI3311 to receive it for Free. A $8.99 value! Min spend $55. Offer ends 8/23/11 at 11:59 PM EST.
  • Restore and care for rubber trim and seals to keep them elastic and looking like new
  • Protects against extreme temperature and UV rays
  • Shoe polish like applicator makes the application extremely easy and smooth
Old 08-25-2011 | 09:07 AM
  #36
Detailed Image
This week's Weekly Special is Chemical Guys Maxi Suds II - 16 oz.
Use Coupon Code WSMAXIS3411 to receive it for Free. A $8.99 value! Min spend $45. Offer ends 8/30/11 at 11:59 PM EST.
  • One of our best selling shampoos, lots of foam, great lubricity, and gentle cleaning power
  • An addicting cherry scent that makes washing your car a pleasure
  • Best applied with a sheepskin wash mitt along with a Grit Guard bucket insert
  • High sudsing formula makes this a great option to use in foam guns
Old 08-31-2011 | 04:03 PM
  #37
Detailed Image
This week's Weekly Special is P21S Gel Wheel Cleaner - 500ml Kit.
Use Coupon Code WSGELWH3511 to receive it for Free. A $17.99 value! Min spend $70. Offer ends 9/6/11 at 11:59 PM EST.
Old 09-07-2011 | 09:15 AM
  #38
Detailed Image
This week's Weekly Special is Poorboy's World Wheel Sealant - 8 oz.
Use Coupon Code WSWHEEL3611 to receive it for Free. A $19.99 value! Min spend $115. Offer ends 9/13/11 at 11:59 PM EST.
  • Properly protect any wheel finish and minimize the amount of brake dust and road contamination
  • Has an amazing watermelon scent that everyone loves!
  • The thinner the application the better, which allows you to get dozens and dozens of applications
  • Apply with a foam applicator pad or soft cloth and remove with a clean microfiber towel
  • Extremely easy to apply and remove, feels ultra slick upon completion
  • Prevents brake dust from etching in to the wheels finish
Old 09-21-2011 | 09:20 AM
  #39
Detailed Image
This week's Weekly Special is DI Accessories Sheepskin Wash Mitt.
Use Coupon Code WSSHEEP3811 to receive it for Free. A $9.99 value! Min spend $55. Offer ends 9/27/11 at 11:59 PM EST.
  • Perfect wash medium to help minimize adding swirls and other imperfections to the paint
  • The natural fibers help pull contamination away from the surface without grinding them in
  • When done using, rinse any contamination using free flowing water than hang dry with leather hoop
  • For best results, use in conjunction with a 2 bucket wash system utilizing Grit Guard Inserts
Old 09-28-2011 | 09:49 AM
  #40
Detailed Image
This week's Weekly Special is Meguiar's Ultra-Cut Compound M105 - 8 oz.
Use Coupon Code WSULTRA3911 to receive it for Free. A $9.49 value! Min spend $45. Offer ends 10/4/11 at 11:59 PM EST.
  • Very effective at cutting through deeper imperfections
  • Finishes down nicely, but we still recommend a finishing polish after 105
  • Commonly used with an orange light cutting pad, yellow cutting pad or purple foamed wool pad
Old 10-05-2011 | 09:42 AM
  #41
Detailed Image
This week's Weekly Special is Stoner Invisible Glass - 19 oz.
Use Coupon Code WSINVIS4011 to receive it for Free. A $5.99 value! Min spend $35. Offer ends 10/11/11 at 11:59 PM EST.
  • Foam based glass cleaning formula that is ammonia free, making it safe on tinted windows
  • Easily removes oily dirt, dust, fingerprints, grease, adhesives, smudges, smoke haze and more from glass
  • Best applied with an all purpose microfiber towel, then wiped clean with a dry low nap microfiber towel
  • Do not apply in direct sunlight or hot glass, otherwise streaking may occur
Old 10-12-2011 | 10:01 AM
  #42
Detailed Image
This week's Weekly Special is SONAX Wheel Cleaner Full Effect - 500 ml.
Use Coupon Code WSWHEEL4111 to receive it for Free. A $15.99 value! Min spend $90. Offer ends 10/18/11 at 11:59 PM EST.
  • Sprays on fluorescent green and changes to a deep red as it reacts with contaminants on your wheel
  • Extra strong wheel cleaner that is very gentle and pH neutral
  • Safe on chrome, alloy, anodized, stainless steel, clear coat and polished wheels
  • High quality spray nozzle provides a fine mist and steady stream which helps conserve product
  • A premium wheel cleaner professional detailers absolutely love
Old 10-19-2011 | 09:53 AM
  #43
Detailed Image
This week's Weekly Special is DI Microfiber Waffle Weave Drying Towel.
Use Coupon Code WSWAFFL4211 to receive it for Free. A $17.99 value! Min spend $65. Offer ends 10/25/11 at 11:59 PM EST.
  • One of the best options for drying your vehicle and most commonly used by professional detailers
  • The waffle weave texture helps pull contamination away from the surface compared to a flat chamois
  • Our microfiber waffle weave towel has silk edging to minimize adding imperfections
  • This towel can hold up to 5 times its weight with water
  • We recommend using the sheeting method prior to drying with the towel for maximum efficiency
  • Always wash your microfiber products prior to first use
Old 10-26-2011 | 09:43 AM
  #44
Detailed Image
This week's Weekly Special is TUF SHINE Tire Appearance Kit.
Use Coupon Code WSTIREA4311 to receive it for Free. A $39.99 value! Min spend $160. Offer ends 11/1/11 at 11:59 PM EST.
  • The first ever semi-permanent tire dressing that looks amazing and truly lasts
  • One coat rich and dark finish, two or more coats is extremely glossy
  • Contains no oils or silicone's that can harm the tire
  • Will not sling off, dries to the touch in minutes and applies with ease
  • Tires look stunning and do not feel greasy or oily at all
Old 11-02-2011 | 10:22 AM
  #45
Detailed Image
This week's Weekly Special is Black WOW Black WOW - 4 oz.
Use Coupon Code WSBLACK4411 to receive it for Free. A $24.99 value! Min spend $170. Offer ends 11/8/11 at 11:59 PM EST.
  • Restore faded and neglected trim pieces, while leaving behind a bold even finish
  • Removes product residue from trim and lasts through multiple washes
  • Only a tiny bit of product is needed, use sparingly
