Special New Special Every Day At www.DetailedImage.com on Top Quality Car Care Products!
#61
Auto Detailing Expert
Today's Daily special (March 20, 2011) is Optimum Opti-Seal & Free Yellow Foam Applicator.
Regular Price for 8 oz is $24.99. Today's price is $18.49!
You can receive email notifications of our Daily Special each morning by signing up for a Detailed Image account
- The ultimate in ease of use when it comes to protecting your vehicle with a sealant
- Simply mist Opti-Seal onto your paint and walk away, no wiping is necessary when applied properly
- Perfect for professional detailers or enthusiasts who are looking for maximum results in less time
- Includes a FREE yellow foam applicator
#62
Today's Daily special (March 21, 2011) is DI Microfiber Mini-Towel.
Regular Price for 6" x 7" is $2.99. Today's price is $2.23!
- Works well at keeping glass and other surfaces clean and free of fingerprints and smudges
- Perfect for keeping your sunglasses clean and free of fingerprints
#63
Today's Daily special (March 22, 2011) is SONAX Wheel Cleaner Full Effect.
Regular Price for 500 ml is $15.99. Today's price is $14.50!
Regular Price for 5000 ml is $99.99. Today's price is $71.99!
- Sprays fluorescent green and changes to a deep red as it breaks up road grime
- Extra strong wheel cleaner that is very gentle (pH neutral)
- Safe on chrome, alloy, anodized, stainless steel, clear coat and polished wheels
#64
Today's Daily special (March 23, 2011) is Chemical Guys Citrus Wash Wheel & Rim Cleaner.
Regular Price for 16 oz is $8.99. Today's price is $6.47!
- Citrus based wheel cleaner that is safe to use on virtually any wheel surface
- Concentrated solution makes this a great value as you can dilute it down 7:1 with water
- Works best when an E-Z Detail Brush is used in conjunction with Wheel & Rim Citrus Cleaner
- Protect your just cleaned wheels with Poorboy's World Wheel Sealant for easy maintenance
#65
Today's Daily special (March 24, 2011) is Lake Country 5" Backing Plate for Porter Cable 7424.
Regular Price for 125 mm is $16.99. Today's price is $12.57!
- Use with Porter Cable 7424 XP and 5.5" Hook and Loop Pads or larger
- Get optimal results with the 5.5" Lake Country foam and wool pads
- Allows you to easily put on new pads and pull of the old ones in just seconds
#66
Today's Daily special (March 25, 2011) is Lake Country Red Foam Applicator Pad.
Regular Price is $2.49. Today's price is $1.79!
- Our softest and plushest foam applicator pad that has two distinct sides to apply products with
- Most commonly used for applying last step products (LSPs), such as sealants and waxes
#67
Today's Daily special (March 27, 2011) is Optimum Car Wash.
Regular Price for 32 oz is $11.99. Today's price is $8.93!
Regular Price for 128 oz is $29.99. Today's price is $22.34!
- An outstanding shampoo that has great lubricity, plenty of suds, and gentle cleaners
- Works great as a maintenance shampoo to maximize the life of your sealant or wax
- Best applied with a sheepskin wash mitt along with a Grit Guard bucket insert
#68
Today's Daily special (March 28, 2011) is Lake Country Green Very Light Cutting Pad.
Regular Price for 6.5 inch is $9.99. Today's price is $7.29!
Regular Price for 5.5 inch is $8.99. Today's price is $6.70!
Regular Price for 4 inch is $4.99. Today's price is $3.72!
- A very popular polishing pad designed to remove light surface imperfections from the paint
- When you need a tad more bite than a white polishing pad, the green pad is your answer
- Menzerna PO106FF polish is one of the most popular products to use with the green pad
- We recommend caring for your pads with Snappy Clean Pad Cleaner
#69
Today's Daily special (March 29, 2011) is Lake Country Snappy Clean Pad Cleaner.
Regular Price is $1.49. Today's price is $1.11!
- A citrus degreaser designed to help release product and contamination from foam pads
- Simply pour into a 5 gallon bucket of water and allow your foam pads and applicators to soak
- To further the cleaning, massage the pads while soaking, rinse with pressured water, repeat
#70
Today's Daily special (March 30, 2011) is DI Microfiber The Great White.
Regular Price for 16" x 24" is $6.99. Today's price is $4.96!
- The perfect work horse towel, that can remove product residue, as well as apply liquid products
- Larger 24" x 16" towel provides more surface area to collect and trap product, dust, dirt and more
- Silk edging helps minimize adding imperfections to delicate surfaces
- Always wash your microfiber products prior to first use, ideally with CG Microfiber Detergent
#71
Today's Daily special (March 31, 2011) is Chemical Guys Hose Free ECOwash.
Regular Price for 16 oz is $12.99. Today's price is $9.22!
- Perfect for mobile detailers, enthusiasts without access to a hose or washing in a garage
- All you need is to fill up 2 buckets of water and you can wash your car, no water source needed
- Best applied with a plush microfiber towel, grout sponge or sheepskin wash mitt
- Environmentally friendly
#72
Today's Daily special (April 1, 2011) is DI Accessories Reclosable Storage Bag.
Regular Price for 24" x 24" is $2.99. Today's price is $2.18!
- Simple solution for storing microfiber towels!
- The large 24" x 24" size offers flexibility to accommodate dozens of towels
- Thick reclosable bags make it a durable long term solution to storage needs
#73
Today's Daily special (April 2, 2011) is Chemical Guys Black on Black.
Regular Price for 11 oz is $12.99. Today's price is $9.61!
- One of the most unique trim restorers that turns faded trim back to a deep factory black finish
- Perfect option for wheel wells, engine bay dressing, tire dressing and exterior trim pieces
- Formerly referred to as Chemical Guys Fade 2 Black
#74
Today's Daily special (April 3, 2011) is Meguiar's Ultra-Cut Compound M105.
Regular Price for 32 oz is $26.99. Today's price is $20.70!
Regular Price for 128 oz is $74.99. Today's price is $59.70!
Regular Price for 8 oz is $9.49. Today's price is $6.74!
- Very effective at cutting through deeper imperfections
- Finishes down nicely, but we still recommend a finishing polish after 105
- Commonly used with an orange light cutting pad, yellow cutting pad or purple foamed wool pad
#75
Today's Daily special (April 4, 2011) is DI Microfiber reTHICKulous Towel.
Regular Price for 16" x 15" is $8.99. Today's price is $6.47!
- Thickest, softest, most plush towel we carry.
- Over 3x thicker than regular microfiber towels.
- Always wash your microfiber products prior to first use, ideally with CG Microfiber Detergent.
