Which OEM cats fit an '08 coupe?
I just yesterday started hearing the rattle at lower RPMs idle that seems to be most associated with the internals of one of the stock cats working loose. I plan to check for the other, simpler potential causes (loose heat shield, etc.) as well, but want to plan for a possible replacement of the cats with a used OEM set.
I'm trying to get an idea of which years/models of G37 or other Infiniti/Nissan models I could consider to be good candidates from which to get a set of used OEM cats. Is it specific to those that have the VQ37VHR engines?
Thanks!
Thanks!
I have the cats off of a 10 or 11 g37 on my 2007 g35x sedan, from what i could tell when I looked into it, the part numbers changed but the cats are the same/compatible for the G Sedan from 2007-2013 and for the g37 coupe from 2008-2013 and the Q40/60 for 2014...
I haven't had any issues with them
Thanks Hashim. I was hoping that would be the case. It gives me a lot more flexibility if I need to hunt for a used OEM set of cats. I'd prefer to get some newer than '07-'08 since that seems to be the period people are reporting the most issues with inadequate internal welds.
RWD.
I thought about HFC, but I'm not convinced that I'd be happy long-term with the increased noise level. Being in my mid-50's, I like the sound as it currently is. Quiet while just cruising, but with a healthy growl when I get on it.
blackgp2006
02-27-2013 05:33 PM
meyog37s
09-22-2009 06:43 PM
