I have a 2010 G37s sedan and wanted to know where to get a straight pipe that will fit the bolt on set-up in replace of the mufflers. I am also open to any suggestions you have on how to straight pipe a G cheap and the right way. Thanks!!
Leave the stock mid pipe. Youll want resonators so it sounds good.
The sedan doesnt have a bolt on muffler delete. Find a local welder or muffler shop. And start there. Remember CHEAP and RIGHT dont play nice. One or the other. Good luck.
Just find a quality shop to do it for you, and don't forget to check how far you want the tips to stick out and double check its nice and even and solid.
If I remember correctly (didnt play around with stock exhaust much) the factory mufflers/axle back section is bolt on and you can remove it and see what you think of the sound before dropping a few hundred at a shop.
Unless you live somewhere with lots of winter, in which case you'd need heat and power tools to separate it because it's all rusted into one piece.
