Gorgeous Custom G37 Amuse Exhaust System
Yeah i'd agree with Polar_g37s cause the amuse is one of the most expensive exhaust out there and best looking. But for the money, Tru dual is the best sound and flow.
There are no significant benefits of a true dual system over a single exhaust system. The main purpose is the same for both systems. An exhaust system on the G is going to add about 10HP if you're lucky, single or dual. If you are buying an exhaust system for bang-for-the-buck, then Amuse is not going to be an option anyway. In which case, a one-off system by Amuse is certainly not going to be an option.
Why go threw all the changes in piping? Why not just run 2 2.75" pipes all the way out to dual tips. Unless its just purely for look. The amount that exhaust would cost to duplicate, would almost amount to a supercharger kit.
Because there is no real, significant benefit to a true dual set-up. Of course looks play a role in exhaust systems. If you acknowledge that there is no real power advantage to a true dual system, then I guess I just don't understand what you're saying. These guys know how to make exhaust systems. As for price, like I said in my above post, if price was a concern then a one-off system by Amuse would not even be on the table.
Fact is... you get no added gains from a true-dual exhaust on these cars. A single 3 inch will reduce some weight and with FI applications has shown additional Dyno proven gains! This Amuse exhaust is also Titanium. So you get added weight reduction (half of stainless). The exhaust is also very exclusive, has significantly less corrosion-almost resistant, Much stronger and this exhaust is made to order... Rare JDM goodness!
