Test Pipes or HFC?
Old 10-09-2012 | 11:10 AM
BL1024's Avatar
BL1024
Test Pipes or HFC?
I'm running the HKS Hi-Power Exhaust and want it to be a little louder but without completely changing the sound of it. Is anybody running Berk High Flow Cats, or Motordyne Test Pipes with the HKS exhaust and could give me some positive or negative feedback on the sound? or even an opinion on which one I should go with? Thank You!
Old 10-09-2012 | 11:15 AM
BluestickG's Avatar
BluestickG
Just depends what you are looking for. High flow cats will make it louder and add power gains but if your looking for the most power output go with test pipes. However test pipes will make your car even louder and and raspy. I run Berk test pipes, however i run an Invidia exhaust because it is a quiet system and helps to almost eliminate the rasp. HKS alone is quite a bit louder then invidia so if you ran test pipes you will get rasp and some drone. But you will have more power
Old 10-09-2012 | 11:58 AM
SwissCheeseHead's Avatar
SwissCheeseHead
HFC>test pipes. No rasp, extra powa, no stinky exhaust smell thing that guys complain about lol. Plus you're not killing your momma earth.
Old 10-09-2012 | 12:21 PM
ARKperformance's Avatar
ARKperformance
you can try resonated high flow cats if you don't want any raspiness
Old 10-09-2012 | 12:31 PM
bluedevils95's Avatar
bluedevils95
I am more for the HFC. TP just smell up the car
Old 10-09-2012 | 12:44 PM
BluestickG's Avatar
BluestickG
I like the smell
Old 10-09-2012 | 12:56 PM
Weiboy718's Avatar
Weiboy718
Old 10-09-2012 | 02:34 PM
BL1024's Avatar
BL1024
Thank you all so much! I looked for video forever and couldnt find it! Thanks Weiboy!
Old 10-09-2012 | 03:48 PM
Weiboy718's Avatar
Weiboy718
You are very welcome!
How do you like it? With these pipes it definitely opened up the exhaust so if you like a little more tone this is for you. I like it but I can't keep them unfortunately.
Old 10-09-2012 | 05:10 PM
enshadow's Avatar
enshadow
im getting fast intention resonated hfc. A lot of people said it makes any exhaust sound better. im just having them put on my ipl exhaust to make it a little louder. Should give it a look since there is a group buy on it also.
Old 10-09-2012 | 10:33 PM
Will.B.'s Avatar
Will.B.
Im running motordyne resonated TP with invidia gemini. Its definitely not too loud at all but is a little raspy at certain rpm
Old 10-09-2012 | 11:16 PM
tbone12's Avatar
tbone12
I have some test pipes sitting in my apartment right now, I havent decided whether or not to install them because I'm worried their going to be to raspy with my FI cat back
Seth Gonzalez (07-13-2020)
Old 10-11-2012 | 06:30 PM
SPDCRZ's Avatar
SPDCRZ
If you want to get rid of those test pipes let me know I am looking for some.
Old 10-11-2012 | 09:55 PM
huwee06's Avatar
huwee06
Motordyne Art Pipes = Beast Mode that is all...
Old 10-11-2012 | 10:59 PM
blackvr4tt's Avatar
blackvr4tt
Highly recommend high flows over a test pipe. The HFC will give you alittle better sound and more power without spewing out emissions.
I hate it when I'm behind a car with no cats, the smell and pollution is disgusting. Using a test pipe is pretty selfish if you ask me.
Quick Reply: Test Pipes or HFC?
