Magnaflow X pipe + Tanabe
Hey just wondering if anyone has this set up? I have seen the the magnaflow x pipe paired with the stock exhaust and its not bad. What are you guy's opinion on this combo?
the magnaflow X muffler and tannabe wont rasp. a magnaflow xpipe and mufflers howver most likely will.
Its up to you. i would go with a full catback so all the piping is the same size. im also not a fan of Frankenstein exhausts either.
Whats the difference between the x muffler and x pipe? Im also running with berk test pipes also
u should go with Exhaust Depot X pipe its direct bolt on and sounds sick.
AND YES THEY MAKE IT FOR THE SEDAN
E.D. True dual Catback system with X-pipe
for $900 you can get an Invidida cat-back, that is full 304 polished stainless and looks great on the sedan. you can get with or with out titanium tips. the picture on the link below actually isnt correct, there is an updated Xpipe and resonators added to the system. Zero drone or rasp
Amplified Motorsport - AmplifiedMotorsport.com - performance audio auto accessories
call or send lou a PM on here, he will get you special pricing.
new INVIDIA gemini exhaust for g35 sedan by AMPLIFIED MOTORSPORT - YouTube
i checked with INVIDIA and just as i thought the Gemini exhaust is not made for the Sedan so that is just a plan ole' Q300. And the design is not a TRUE X pipe. Look @ the design of the Exhaust Depot. Now that true X pipe, no muffler canisters to slow u down just pure resonators to keep the sound in check.
