confused on Test pipes and HFC for 09 G37x sedan
Ive been doing a ton of research on which Test pipe or HFC to run on my 09 g37x sedan, and have found it hard to figure out which ones fit my car. I've found a bunch on e-bay and other sites that list g37x but when I ask they reply with only the coupe or only the RWD?? I only looking to free up a few my horses and add a bit of tone the exhaust note. I dont want super loud and have zero plans on any big mods. Ill prob stick to the test pipe or HFC and an intake prob the RC2. or JWT one.
Any help or links to sound clips would be ideal!!
Or even a guideline of what other years models, fit as well.
as I know, only Motordyne ART test pipes require some modding for AWD sedan (moving side branch resonator to fit AWD transfer case).
all other pipes and HFCs are direct-fit for both RWD and AWD
thank you guys. what is the diameter of the unit I should be looking for? Will a G35 sedan test pipe work as well?? If I was going to go with a HFC I would steer clear of the ebay stuff but I figure a test pipe is nothing more then some pipe and flanges
Some of the things stated here are false, the test pipes for the coupe and sedan are exactly the same, its the same engine... I have test pipes, so it doesnt have any sort of emmisions device, and their great. Sound wise their going to sound like **** if you dont have some sort of exahust on the sedan, coupes sound pretty nice with the test pipes. I ended up removing my mufflers so I just have resonators. It is loud but acceptable.
Fast intentions designates a difference between sedan hfc/tp and coupe hfc/tp. Is this just their own designation or is it a fitment issue? if it's not a fitment issue, FI cat-pipes might be a consideration.
Fast Intentions
but, not sure if they'll fit. does anyone know about fitment?
Fast Intentions
I figured the Rwd sedan to be the same if not similar to the Rwd coupe and the same for the Awd coupes and sedans. But I expected the Diameters to be different and obviously the rear sections to be different. So does anyone have a sound clip of a test pipe or HFC mounted to a stock exhaust on an AWD sedan?
just sayin'...
and fyi, more o2 WILL set off a cel (bank 2 sensors).
I'm not so concerned about emissions. Here in IL they dont do visual tests its only a Cel test via the OBDII. I haven't run cats in any of my cars for years. the Non fouler trick works like a charm. And I've noticed many of the Test pipes for this car have the long tube for the o2 sensor already extended. That wasnt the case for my Mazdaspeed Protege. Hence the use of the Non foulers......
Tecnically a Test pipe is just bent pipe with flanges so its hard to mess those up.
But I really wish I knew which of these Stainless ebay specials will work. Or even how they will sound
The Fast Intentions Test Pipes will free up a healthy amount of HP.
Call up Tony: (818) 882-2828.
Caution: they are LOUD.
Also, I heard their HFC's are good.
Both have O2 sensors and will NOT activate a 'Check Engine Light'.
i just installed my BERKS HFCs like 2 weeks ago man and holy **** i love em and it didnt throw my CEL most test pipes will throw ur CEL but ill try to get a video of the car up for u so u can hear what it sounds like
