Car hesitation and bogs with stillen gen 3
I installed the stillen gen 3 the other day and driving around I've noticed a hesitation and bog when I floor it as the car downshifts . I checked all the connections and maf's. All are good. I did disconnect the neg terminal while I installed so the ecu should be cleared.
Is it the ecu learning and figuring things out and the problem should go away with driving ?
ive heard that alot of people that install the Gen 3s or High flow cats or test pipes get this. then they get a tune from uprev and its gone. may be what you need. im getting the bogging hesitation almost like my transmission is confused on what gear to pick. ive got HFCs and an exhaust. i picked up a hypertech tuner used for $200 (couldnt pass that up) ill see if that helps me.
I get that sometimes, thought it had to do with the transmission though
Yeah, it could be a transmission problem. Ironiclly I reset the ecu and now my transmittion is giving me the problems people have been talking about. Before this, my tranny worked great.
SpeedBallDEVIL
08-12-2015 04:30 PM
connoisseurr
08-11-2015 09:30 PM
