Help Do YOU GUYS HEAR ANY HISS OR RASP? ARK PERFORMANCE INC HFC PROTOTYPE INSIDE
I dont know what to say. We have differentiated ourselves from HKS to a point where it is two totally different exhausts in sound, performance, quality, and at a better value.
I'll start from the front to back.
Flanges are thicker
Piping is thicker
X Flow Chamber as oppose to H pipe
Our signature dual resonators
Double welded caps on our helmholtz pipe
length of neck of the helmholtz pipe
Size of preforation of the helmholtz pipe
Fully welded tips in 3 different various ( Burnt, Polished, Tecno tips)
You guys must release that there are only so many ways to make an exhaust for a specific car. To utilize the Helmholtz pipes, unless you want them to be 36 inches long, it must be place in that area in order to eliminate the frequency that creates drone in cruising speeds.
To put it simply, we made a better exhaust overall.
And we will continue to improve upon our products.
Thank you.
Team ARK
PS. We worked very hard to bring you an HFC that the community wanted. I just hope that you guys will be able to appreciate the work we put into this product.
Flanges are thicker
Piping is thicker
Thank you.
Team ARK
The truth inside an Ark Exhaust.....Ark you have some explaining to do! - Genesis Forum: GenCoupe Hyundai Genesis Forums
You're right. I don't think you guys copied HKS with a burn hole lolz.
wat
wat
wat
wat
Customer cut our pipes, welded it back shut. No dynos, No videos, Now a non active member on the board.
Our response thread.
? Ark performance inc: ARK EXHAUST AND DUAL CHAMBER EXPLAINED IN DETAIL - Genesis Forum: GenCoupe Hyundai Genesis Forums
Also.
Inside the HKS Exhaust H-Pipe - MY350Z.COM Forums
As a vendor, I would expect more from you. Defend yourself, absolutely, but to then throw the company you clearly ripped off under the bus? Come on...
Since we're now sharing things... What is the reason that these pictures of your product do not make it into your beautiful professional photo shoots? Look at that quality and craftsmanship!
b2autodesigns
Brakes/Suspension
128
03-24-2018 07:44 PM
