HFC vs resonated TP,,noise/rasp
Any other TP will always be louder and raspier than HFCs. Just get ART TP and apparently judging by all the videos they are just as loud as HFCs with minimal to no rasp depending on the rest of your exhaust setup. I should have mine installed wednesday and can confirm then.
well right now i have BERK HFC and magnaflow and there is something wrong at wot sounds VERY metalic/raspy and im trying to trouble shoot to see if its my berkCAts,,,i might try resonatedHFC instead of resonatedTPs, but ive beet wasting money on install/reinstall
The Magnaflow exhaust is very similar to the Fast Intentions exhaust. They sound almost identical and they are made similarly. FI used Magna's mid-pipe back on their older exhausts, even. My point is... I have an FI exhaust and I used to have the FI HFC's as well, and with that setup, I had zero rasp anywhere whatsoever. Thus, I believe that it's definitely the Berks' fault from which you're getting so much rasp. Throw on some FI HFC's, and it'll probably be way better. TP's will probably make it worse, though.
SON415
09-28-2015 05:49 AM
