Best intake for G37s 6MT
What is the safest/best intake for my 2008 g37s coupe.. it is my everyday driver. I am going to do intake, headers and exhaust. I dont want to have to worry about hydro lock.
i dont know why everyone worries about hydrolock. The only intake people have experienced that with in the injen (that ive read on the forum). Get whichever you like more. Stillen/takeda cai/injen make the most power. and any short ram is easier to instal and louder! dont worry about hydro lock. unless you drive under waterfalls on a normal basis
I hear ya, i had a AEM cold air on my civic that was practically on the ground and never had a problem. I am stuck between the Injen Gen 3 long tube and the Takeda attack cold air they both say 17-20hp gains... Injen has 2 filters, Takeda has a shared one! at this point is it just preference?
Cost will be the biggest difference. Takada's are less then Stillen but are newer. They are gaining popularity though and there are some dyno runs to show they are nearly equal to Stillen in HP gains. Stillen may cause some radiator support grinding for install although that isn't always the case. Takada's central single filter fits right behind the Mt. Fuji emblem on the front grille and gets great air flow. Stillen's sit there also so flow is similar. Neither one will have much problem with water intake unless going through huge puddles or freaking torrential downpours that cause your whole front end to gasp for air. I've definitely never had any issues.
There are a lot of different opinions and preferences as to CAI, exhaust, hfc, x-pipe combos. The thing is there are always new options coming into play also. For instance Berk just came out with a new cat back exhaust that is becoming very popular. They are a well know but very small company that specializes in these exhaust systems. Their work is top notch and the quality of their product can't be argued. Others prefer Fast Intentions or Ark or Invidia Gemini. I suggest you determine your budget and review a bunch of other threads about the same subject and listen to some videos. They will help you get an idea of what the different sounds will be. They all sound different especially when combined with other components.
You asked a very broad question, so unfortunately you are getting a very broad response. Good luck with your search though. For what it's worth, I am extremely happy with my setup and feel that the Stillen combination was designed and tested together so they match superbly.
superjoey
31
03-22-2023 11:56 PM
