Help Help Asap R2C = Dead Car!!!
Old 04-05-2011 | 02:57 PM
  #46
VossenG37S's Avatar
VossenG37S
Btw i noticed today when I pulled MAF sensors out the stock air boxes they need to be flipped around to fit into the R2C pipes! Is this normal? I tried to put I'm exactly how they sit in stock intakes but the holes don't line up unless sensors are flipped.
Old 04-05-2011 | 03:02 PM
  #47
ANMVQ's Avatar
ANMVQ
man u serious?? WTH, Sound like the MAF's are not reading at all? There nothing in the pipes pluging anything, No popcorn and anything is there, As dumb as it sounds but I'm out of thoughts also?
Old 04-05-2011 | 03:18 PM
  #48
VossenG37S's Avatar
VossenG37S
Pipes are clean of anything that may b in the way. Still nothing just dies after install. Everything in and secure . I will try again tomorrow I gotta go to Work . maybe these pipes are just a bad batch. Dunno
Old 04-05-2011 | 03:19 PM
  #49
chuckie311's Avatar
chuckie311
Drop A Gear and Disappear
you cant flip the MAF sensor around it wont read right they are only suppose to go in one way..thats problem the problem right there..swap the tubes so the face the right way if you can or does it not line up??
Old 04-05-2011 | 03:21 PM
  #50
CDONNS's Avatar
CDONNS
.....? If the sensors have to be reversed then the issue is with the position in which they drilled the holes (used for screwing in the sensor). Its an R2C issue, get new pipes. Use my thread to compare screw hole orientation...
https://www.myg37.com/forums/picture...ut-to-r2c.html
Old 04-05-2011 | 03:43 PM
  #51
ANMVQ's Avatar
ANMVQ
No they should not have to be flipped around that maybe he issue right there, If I remember there is a FLOW arrow on the stock intake pipe no?
Old 04-05-2011 | 03:57 PM
  #52
chuckie311's Avatar
chuckie311
you are correct they can only go one way otherwise issues..
Old 04-05-2011 | 04:24 PM
  #53
ANMVQ's Avatar
ANMVQ
Well at least we all figured the issue out with him.
Old 04-05-2011 | 04:30 PM
  #54
breftayka's Avatar
breftayka
Or so we hope! Hopefully Kyle or R2C take care of him.
I'm glad he got a lot of responses pretty fast, he helped me out when I was looking to get my Vossens.
Old 04-05-2011 | 04:33 PM
  #55
ANMVQ's Avatar
ANMVQ
If they made the mistake in making the tubes, The will take care of him. I'm glad he did to he has been on a few of my threads also, With some advice.
Old 04-05-2011 | 05:33 PM
  #56
VossenG37S's Avatar
VossenG37S
Thanks everyone I'm gonna contact Kyle and see if I can get new tubes! I really appreciate the help really. Has been a headache but hopefully I can get these replaced cause this is no fun.
Old 04-05-2011 | 05:42 PM
  #57
VossenG37S's Avatar
VossenG37S
I'm on the phone W R2C I hope this is the issue cause nothing else makes sense!
Old 04-05-2011 | 05:45 PM
  #58
UNCTYPE-S's Avatar
UNCTYPE-S
See what happens when you jump into someones thread and steal what they are looking for?
Old 04-06-2011 | 12:00 AM
  #59
TVPostSound's Avatar
TVPostSound
I just checked mine.
MAF clips face the passenger side, and the writing on the MAF sensors is towards the filters.
GL
Old 04-06-2011 | 12:43 AM
  #60
VossenG37S's Avatar
VossenG37S
Awesome thanks everyone ! I got busy at work but had a voicemail from R2C it seems there customer service is great! Just kinda upset at time waisted. This should not happen when u drop $400 on intakes. But I'm sure it's gonna be resolved . Thanks again for the help.
