Help Help Asap R2C = Dead Car!!!
Old 04-05-2011 | 03:25 AM
infamousstunna1's Avatar
infamousstunna1
Originally Posted by VossenG37S
Throttle bodies have been fully cleaned bro! I was running the car all day and had it at the track Friday. All the sudden limp mode tonight after intake install. Something went wrong I just can't figure it out.
Yeah, I can't see any other reason why this would happen after an intake install...unless (and I hope it's not the case) the maf sensors were damaged somehow.
Hopefully you'll be up and running in the morning
Old 04-05-2011 | 03:34 AM
GraphiteG37S's Avatar
GraphiteG37S
Any other help ??? Please guys your input matters.
Did you already reset ECU by leaving the battery off the terminal for ~15 mins?
Limp mode?... did you ground or cause a short while you were installing the intakes? Kinda strange why all your dash lights are on.
Old 04-05-2011 | 04:29 AM
VossenG37S's Avatar
VossenG37S
so i put everything back to stock and everything is normal running perfect w NO CEL...
WTF is going on???
Old 04-05-2011 | 04:38 AM
Doggy's Avatar
Doggy
It's a sign...: u ain't meant to have intakes. Did you have these before?
Old 04-05-2011 | 04:39 AM
VossenG37S's Avatar
VossenG37S
yes i had same ones b4 . am i missing something ? ughh such a pita i just dont see what is wrong
Old 04-05-2011 | 04:40 AM
Doggy's Avatar
Doggy
The same exact intakes? Or a new r2c? Just call the company and see what's up.
Old 04-05-2011 | 04:42 AM
VossenG37S's Avatar
VossenG37S
Same R2C intakes I had b4 dunno what's up w these but my car not liking them.
Old 04-05-2011 | 04:51 AM
chuckie311's Avatar
chuckie311
Drop A Gear and Disappear
wow totally weird why dont you try replacing one side at a time and start the car and see what happens..leave one side stock and on the other install the rc2
Old 04-05-2011 | 04:53 AM
VossenG37S's Avatar
VossenG37S
Yea man i will try tomorrow . Dead tired lol but good idea . Let's see what the problem may be.
Old 04-05-2011 | 05:29 AM
BooSa37's Avatar
BooSa37
There is definitely something not right on here. At the moment I cannot think of anything, but by any chance did you drop any of the MAF sensors those things are super tender, check to see if they have dirt on it. Let us know
Old 04-05-2011 | 08:18 AM
AUS10TAT10US's Avatar
AUS10TAT10US
Like people have said, this is really odd...something def is not right. I installed these intakes last week and everything is perfectly fine. Only thing I can think of is the MAF sensors. Try re-installing them again with the negative side of the battery disconnected the entire time.
Old 04-05-2011 | 10:29 AM
Neal376's Avatar
Neal376
I was going to suggest to uninstall the intakes, then reinstall them all over again from start to finish.
make sure the rubber gasket under the maf sensor is installed properly and every clamp/vacuum line after the maf is secured.
Old 04-05-2011 | 10:35 AM
Modme's Avatar
Modme
Get a reader and check thE CEL. It'll give you a clue which component is causing the problem
Old 04-05-2011 | 11:14 AM
  #29
breftayka's Avatar
breftayka
It has to be the MAF sensors man. Check the ports on the R2C for dirt or anything that could be interfering.
Old 04-05-2011 | 11:17 AM
  #30
Modme's Avatar
Modme
If there was something wrong with MAF and you fixed it, You still need to clear the code. Leaving the battery disconnected will not clear CELs codes. You need to use a reader to clear it.
