Stillen - truth to this comment?
So what you're saying is someone more knowledgeable about a particular subject should just hoard that knowledge and not share it with others? (which, by all accounts is only the main purpose of this forum)
Gotcha.
Obviously you haven't seen the genius at work or the aftermath? Scary site. Think Hiroshima x 100000.
this is the banter Mike and I go through...by replying to a post that wasn't directed to you i assume you want to pick a fight. did you want us to strap up and e-thug it out? LOL
I'm not much of an e-thug. A cyber smartass, sure.
Since we live so close, there'd be no reason we couldn't discuss our mutual appreciation of automobiles over some beer and wings.
Speaking of stock tune, on my car acceleration pre-tune resulted in AFR's in the 10-11's which makes sense. While R2C's filter is less restrictive then stock, it isn't a bloody T-Shirt. Also the stock tune is designed for reliability and world wide deployment and is a one tune fits all application. Getting a tune is not returning AFR to normal, it's adjusting AFR for optimum power which is quite different from the stock tune's target. This is why you can just get a tune on a stock G and gain about 10Whp. That's part of it anyway, iginition timing is also tuned and has a similar performance curve. The G was much closer here which probably explains why just adding air does as well as it does. Also a tune will produce maps that are specific to your car, octane and environment. Interesting vid here on value of proper timing.
YouTube - Haltech: Ignition Timing vs Air Fuel Ratio
Secondly there seems to be a belief that you can't get enough air, the graph below would suggest otherwise. You're aiming for mid 12s. This is why I think it's important to compare intakes post tune. Just because an intake is so free flowing it can overwhelm LTFT better then one that's less free flowing, doesn't mean that both with a proper tune wouldn't produce similar results. As long as both can deliver "enough" air at similar temperatures the results should be the same. Which come to think of it would be another reason for dyno comparisons to possibly favor stillen with fans blowing on the filters vs filters in the engine bay. Would fans really simulate the airflow experienced under actual motion? Room for doubt there.
Sorry didn't mean to change point on the discussion or start a intake war, just relaying some thoughts on the topic at hand.
...but seriously, i've been looking for a good wing place.
hey wait a minute, aren't you the kid with the mazda 3? did you just get a G?
LOL @ thread comments
I can tell you first hand that the Sedan exhaust is very restrictive. Any exhaust upgrade would be better than stock. Have you guys actually look at the exhaust piping under the sedan? The OEM sedan exhaust looks like it belongs on a 4cyl civic.
I bought the Stillen exhaust from a member on this site after driving around for about 5 months with just the Stillen Intakes and High Flow Cats. After adding the stillen exhaust, the car drives like a beast. As a reference I used to own a 08 G37S 6-MT coupe w/ Fast Intentions High flow cats, carbon fiber exhaust and stillen intakes. I traded in he coupe last year for XS Sedan (MD Weather). I carried over the stillen intakes and high flow cats from the coupe and installed them on the sedan.
Also, with just the same mods on my sedan (I/E/P) as I had on the coupe, my sedan is way faster than my old coupe, no comparison.
I have some friends in the regional forums that have seem my car run, and can contest my Stillen Exhaust was a big improvement. Stillen Intakes, High Flow Cats and the Stillen exhaust has transformed this car.
Edit: added pic of my old coupe.
