Help HFC fitment on G37x Sedan?
Can anyone confirm this will work? I'm looking to get some HFCs for my 2010 xS sedan. I know FI has pics of their sedan CBE (for both RWD and AWD) on their website, but it's a bit difficult to tell if the cats are the same or not. I'd imagine so, but forking over $400+ without knowing for a fact just isn't going to happen.
Pics are here of the CBE where you can see the stock cats:
Fast Intentions
Specifically the middle-left and bottom-left photos.
Trying to get a hold of F.I. right now is difficult... understandably so! But if anyone else has any word/thoughts, post up!
*EDIT* Just heard back from Berk. They say they are the same, and will fit the X sedan, FYI!
Tony from F.I. finally replied... fitment is all good!
Fast Intentions
Ok... I ended up going with some ERZ HFCs... Updates when I get/install them.
ERZ performance / CNT RACING 09-10 Nisasn 370z High Flow Catted Pipe
ERZ emailed be back concerning the fitment for the G sedan. They said their Z HFCs do fit the G37 sedan. I didn't ask about the X since I can't imagine how awd would alter the cats.
I can confirm they fit. And any other brand will as well! Install went fine, except for those dreaded header bolts. Needed to torch them. Heh
Threw a P2A03 today so there may be a leak at one of the header flanges. Most likely an installation issue and not one with the HFCs. Rasp is quite noticeable between 2-3k RPM but they just need to be broken in for a week or two according to the Z guys.
ERZ / CNT racing team up to make a test pipe for the G37 also
CNT performance G37 resonated test pipe
Looks like the driver's side o2 sensor was loose. Took it to the muffler shop down the street and he could actually unscrew it with his hand. lol
So far, a little over 50 miles on the car after it was tightened. The code would always pop up beforehand. I'm hopeful, but we will see. heh
