Backpressure: The MYTH and Why It's Wrong
#37
Hello Mike,
Good information on this post, and by coincidence good choice of video clips. In the first clip (of the 08 vette) at around 00:11 to 00:13 when the car decelerates, what causes the cracking/popping?
I was about to head over to corvetteforum.com to ask, but saw this here so figure I'd ask you as well.
Thanks in advance.
DC
Thanks in advance.
DC
I'm not sure what the difference between X and Y pipes are for net gains, but I do know that properly engineered H-pipes will have the same performance gain as a X pipe. The key is that the exhaust pulse overlap on the H-pipe has to be the same as an X pipe for the performance gain to be the same. The difference is the sound; X-pipes give a higher pitched sound, while H-pipes give a lower sound. (Think regular Vette with a catback and stock H-pipe [which btw is crap], and a Vette with a X-pipe and catback)
Z06 with Exhaust
YouTube - 2008 Corvette Z06 with Corsa Exhaust and CAI - Auto Addiction ltd
Z06 with Exhaust and X-pipe
YouTube - 2008 Corvette Z06 With Corsa Mufflers and X Pipe By Serious Autosport
Note how the first clip has that typical "beefy american muscle" sound, while the second one doesn't.
Z06 with Exhaust
#38
Hello Mike,
Thanks in advance.
DC
Thanks in advance.
DC
I don't have any firsthand experience with V8's.
hooey_b (10-18-2015)
#40
It's usually unburnt gas combusting somewhere in the exhaust. You may let off the gas pedal, but if the injector cycle is already started, it will still finish, causing the engine to run rich, and that extra gas is pushed out with the exhaust. Once the exhaust is hot enough, it'll ignite as its coming out. (Usually the cat takes care of this, but with HFCs or a test pipe, the popping is much more noticeable).
#41
This post explains what I want to tell a lot of people on the forums, but you have to overlook ignorance on here or you'll drive yourself insane trying to set the story straight all the time. Article is spot on, but it didnt mention anything about the two different pulses. The first and by far fastest traveling pulse is the energy pulse that exits when the valve opens. This is where muffler, cat, and x,y,or h pipe placement is crucial. This wave travels much much faster than the spent gases and will reflect (hence its name reflective wave) or resonant many times, thus timing its frequency helps scavenge the gases. The second pulse is the obvious gas pulse. Good write up and I don't know why its referred to as back pressure either. Its just a pressure differential between the cylinder and ambient pressure. When referring to a valve or anything involving different pressures "back pressure" is never used, only pressure differential.
