Butterfly Exhaust Valve
![Unhappy](https://www.myg37.com/forums/images/icons/icon9.gif)
Hi All,
I have been searching the Forum on this topic but couldn't find what i was looking for.
I have been searching the Internet for a solution for controlling the sound of my exhaust system but only came across this. As i have not heard anyone talk about it, i am in a doubt on whether i should or not try this.
I read the following article:
Browser Warning
Please let me know what you think and if anyone has experienced anythiing similar then i would appreciate any comments you may have.
Thanks
daBlue
Browser Warning
Thanks
daBlue
Well, then is there any other solution? I remember getting into a Holden and it had a button that switched between through pipes and normal exhaust system. Te sound difference was noticeable, and i would like to acheive something like that but without losing on the HP
![Confused2](https://www.myg37.com/forums/images/smilies/confused2.gif)
![](/images/staff.gif)
See if your aim is to reduce the exhaust note without hurting performance, you'll need some mufflers and resonators, those valves will hurt especially in the high end.
If you however plan on getting them to bring the exhaust note down when you approach cops etc.. then it might be a good idea actually and I have been considering it for a while, especially after my headers come in.
That valve takes it one step further. Like JLai says you lose bottom end with freer flowing exhaust. This valve works off vacuum so that it closes at low RPM to give you the get-up and go, and then opens at higher RPM for better breathing. Kind of the best of both worlds. Motorcycle manufacturers have started doing this their sport bikes so you get the torque and the HP.
I'm not sure OP is doing this as an HP mod, as this would require some R&D, don't expect to just throw that in, close it down low and start burning rubber.
He just wants a simple mod to control his exhaust note to avoid unwanted attention, correct me if I'm wrong please OP
I understand that. I was saying what I was saying for anybody that is performance minded. This valve is more than OP probably needs. This would be a great addition for people with Test Pipes and a high flow exhaust... performance wise.
But for the OP he should just look up electric cutouts.
Hi All,
This conversaton is becoming very intersting for me now.
Sam, you are right on the spot, i am looking at a Mod by which i can install headers, exhausts and all the lot, yet void being caught by traffic police for a noisy car.
Mind you, you may also want to be quite and avoid attraction when you are out with your girl and trying to have a peacful quite time![Biggthumpup](https://www.myg37.com/forums/images/smilies/biggthumpup.gif)
Kahboom, i have come across the Apexi silencers, but i am not sure of how easy are they to install and control. Any idea?
Can anyone else provide feedback on similar exprience on other cars?
Its not going to quiet your car down from what you already have. If you want to make it quieter, then you need a silencer like Kahboom mentioned.
