installed gtm test pipes, and i have a problem
#32
Sounds like the traditional exhaust noise to me, just amplified by the test pipes. Someone else had a comparible setup a little while back and they were complaining of the same issue. It turned out to be a pipe on the magnaflow catback shaking when reving and letting off. Never found out if there was a solution to fixing it or not.
#38
most VQs incl. G35 and 350z (so far all VQs I have heard) have this. even stock setup has this noise.
Depending on an exhaust, mostly HFC or testpipie, this noise is amplified.
You shouldn't hear this much while normally driving with stock setup though. Only when revving at neutral.
I kinda like it. LOL
wattles
09-30-2015 09:19 PM
