Review My New Injen SRI
#109
UPDATE: So late last night I decided to head out to the garage and put the Injens back in my car. This time I did NOT reset the ECU. Took her out for a spin today and WOW....what a difference (in a good way). They sound great....and my car does pull harder. My butt dyno says NO loss of torque. I WILL be keeping them!!!!
Only time will tell how the ECU adjusts to these. I'll run them for a while with my new Tanabe exhaust then get a custom tune this fall to make sure I'm not running rich/lean.
SO...for those who subscribed.....go for the Injens! Just don't reset your ECU....I don't think that's necessary anyways. I'm glad I didn't sell these....
#111
Former Prez of LA G'Z
With the Injen CAI/SRI and Tanabe mufflers your not gonna be running lean or rich without a tune so I wouldn't worry about that. The only way to run rich or lean is by intakes, and if the Injen CAI/SRI is keeping the ratio VERY close to stock you are perfectly fine!
#112
good to hear man
#113
#114
#116
Hey guys.
Just installed mine today. After sitting in my room for a month!
I had problems with that rubber tubing that holds the pipes to the velocity stack, that sucker kept slipping off when I tightened it. cleaned it up a bit and it seems fine right now. I'm scurred they might slip off while driving and my engine sucking in contaminated air. I'll keep my eye on them.
Anyone have the same problem? solutions?
#118
Hey guys.
#120
Glad to hear I wasn't the only one with that problem with the rubber connectors slipping. That SERIOUSLY started to **** me off. It's got an oil-like coating to the rubber (probably to keep it pliable).....Mine has stayed put though thankfully.
