My Borla Review...
My Borla Review...
For starters I'd like to point out I have Berk HFC's and I combined them with a Borla Exhaust today...
DISCLAIMER: I've never seen or heard the Borla in person...I purchased based on reviews and sound clips online...
Thus far I think I may have made a mistake...I have an incredible amount of rasp (probably in large part due to the HFC's)...They sound GREAT upon startup...Very deep and aggressive...They sound good in the lower RPM's and they scream in the higher rpms...The rattling and rasp is kinda "cheap" sounding? Atleast thats what I'm hearing from them...I stood outside the car while my brother drove it away and I really didn't look the rattling and rasping in the higher rpms...
I had my brother drive it and he had the same review...Loved it at some points, hated it at others...
Inside the tunnel and at WOT the car is about as scary loud as I've ever heard (I actually enjoyed that part)...We both loved it to be honest....
As for power gains? What gains? I did NOT do a before and after dyno...However, I used the same shop and same dyno that we installed my Berk HFC's on nearly 1 year ago today...Weather, humidity, and temp were relatively similar...Today was 8 degrees warmer then on my Berk Dyno...
I ended up LOSING 2whp and 2lb tq through 3 of the 4 dyno pulls...One of the pulls had me gain about 5whp in the top end...
I have to say I was shocked and really upset with those results....NO, I wasnt expecting 20whp...But I figured with the high yields this has gotten from others on the forum that 10-12whp should have been EASY...I was wrong...I'm assuming my Berks had something to do with this...But MaxtotheG37 had the same combo and got huge results so I'm unclear as to what the f is going on...
Not sure what to do at this point...I'm considering selling them already (although I'll be eating the costs of an extra install and reduced priced Borla for sale)...
I'll keep them on for a couple days to see if I get adjusted to them...
Did you reset the ECU? Try that, or give it a few days and then see how it is, the ECU has to learn..
I would've waited a few days THEN done a dyno, but yeah you should not be seeing losses for fooksakes.
Glad I heard about the rasp, this was near the top of my list for next mods but now maybe it's a FI or MXP...can't have rasp, hate it.
the HFC's are probably causing the rasp... you should give it a little time for break in. i have the same set up and it is only raspy if i punch it on a cold start. after the engine warms up, it's fine, after about 2 minutes?
I got the borla too. The borla exhaust alone sounds sweet. Had it for about three days now and I love the sound. Though I'm having some issues with a weird noise coming from the front of the car, underneath. Also I can't slow rev past 4000rpm's. As far as the noise it might be the actual install, not the exhaust itself. Taking car back to get it checked out.
Little bit of rasp here and there? I have that too. Rattling noises? Don't have that, you better get it checked out. I did the install with my brother in law and it went well. We took our time and made sure everything was triple checked tight. I get a bit of drone right at 2000-2050rpm, but i'm usually cruising right above that so it's not an issue. Don't really know what to say about your issues besides make sure everything is tight. You should see some gains so reset the ecu and take it out for a couple days.
I get a little rasp with the borla exhaust at about 3-4 rpm's. Pretty sure with HFC's I'll get alot more rasp. Just got the exhaust installed and I'm already thinking of getting a different one. Get some vibration when rpm's are coming down. Weird. MXP maybe.
That's why you don't want to put your HFC's on huh?
