First Dyno Run (Mustang Dyno) aka Ball Braker
Just a couple for now, I will get all the runs without Headers and Cobb and viceversa once they fax them to me. Big thanks to Japtrix and the Crew. From the tuner, headers are a waist of money, havent seen any positive results yet. These are with headers and Cobb Stage 2 and 2+. The lower numbers are from Cobb 2+. My review No gains from headers and loss of Torque. Final report.
They extract the max power with the OEM components, but once you install aftermarket parts its a totally different ball game. His car would def make bigger numbers properly tuned... no doubt.
I do agree with you tho.. OEM setup is pretty potent.
Wrong smokey. Headers increase volumetric efficiency. If that was the only advantage of headers there would be many other parts more easily manufactured than headers. The faster you can get gasses out, the faster you can get air in. The more air in = the more fuel in. The more fuel in the more power out.
#30
It's a very mod friendly engine. so was the last VQ. one of the best(if not the best) on the market. hell. why you you think hyundai slapped it in their genesis drift car.(the *******s)
It's a great motor for modding. Just need to find the right parts and tune. Headers usally reduce weight, not increase power. Headers are a great investment if your FI. I'm captain research when it comes to gains.
How exactly was the VQ35 one of the best mod friendly engines on the market? If you're talking about F/I, that might be more believable, but on the N/A side of things their gains are nothing to be bragging about, and if anything they might be a little bit on the short side, given the displacement of the engine. With the full bolt on modifications from intake to exhaust tip and an actual tune (not a flash or pre-done map) the gains are under 40 whp.
And on your headers comment, are you saying that for specifically the VQ engines? Because many aftermarket header applications are primarily aimed to increase power, and generally speaking, they also tend to be one of the best bang for buck modifications for a huge range of cars. Saving weight is a very negligible amount as headers aren't very heavy to begin with.
