G37 TWIN THROTTLE BODY Weapon R Secret Weapon Air Intake System
Well, the company that I was working with on my wheels told me they have the Weapon R intake for sale, I haven't seen these for sale around here, or heard much about them, so someone hit them up and order a set.
DescriptionThe Secret Weapon Intake was designed, to increase air intake volume to the engine. The concept is to create two different air velocity profiles, one traveling at higher speeds than the other. This technology increases air volume and speed to the engine, which naturally feeds the engine 3x more air than the conventional air intake system. The intake pipe is bent out of high quality 6061 Aluminum on our Automated CNC mandrel bender. Polished to a high show quality finish. The SW1 Air filter features a tuned velocity stack to increase velocity and decrease turbulence. The Secret Weapon uses two important laws of physics to increase airflow. The first law is Boyles law. This law basically states that as air velocity increases, its volume increases as well, while the pressure decreases. The second law is the Bernoulli Equation, where a moving fluid (in this case air) has a lower pressure than air that is standing still, or is moving slowly. This same law is used in NASCAR for both downforce and "drafting." When we increase the air velocity in the intake, we create a low pressure area that draws a higher volume of air than a standard intake would. In layman's terms, we are creating a vacuum effect using natural laws of physics.
Pipes only come in polished. Due to some manufactures restraints some intakes only have a single tube design. Prices have been adjusted to compensate for this. Every Intake will come with the SW Filter!
Link to website- http://www.2kracing.com/Product/73736.html
Pic
Pic
![Name: weaponr.jpg
Size: 57.1 KB](https://www.myg37.com/forums/attachments/intake-and-exhaust/169978d1501889538-g37-twin-throttle-body-weapon-r-secret-weapon-air-intake-system-weaponr.jpg)
Have not heard anything good about these :/
__________________
__________________
![](/images/staff.gif)
well, you're the one who's still ballin maybe you should steup your game up and go for it :P
