Help Berk HFC noise
i know exactly what u are talking about. i have the same exact sound u are describing. is it this:
<embed width="448" height="361" type="application/x-shockwave-flash" wmode="transparent" src="http://i32.photobucket.com/player.swf?file=http://vid32.photobucket.com/albums/d14/DCkidd1/new/MVI_0438.flv">
i think the noise is coming when decelerating
I installed mine about 500 miles ago and haven't had any problems. In a couple more heatup/cooldown cycles I'm going to get back under there and make sure things are still tight. It's probably something loose. Get under there and tighten up everything.
It seems to have gotten a little better
NO, you have the infamous OEM Exhaust rattle, that's a completely different noise.
I had a mechanic listen to it and he's convinced that it's something touching the HFC's externally, like a heat shield or something, that's making it rattle. I'll have to find time to get underneath and look at it.
<embed type="application/x-shockwave-flash" wmode="transparent" src="http://i32.photobucket.com/player.swf?file=http://vid32.photobucket.com/albums/d14/DCkidd1/new/MVI_0438.flv" width="448" height="361">
It probably is. When I put my HFC"s and Exhaust on I almost missed a couple bolts that were loose. Caught them on my last triple check go around.
Well I believe I have found my culprit making the HFC noise. When underneath the car tonight installing exhaust, I noticed that my Tanabe front under brace seemed to be touching something on one side. It was about 1 or 2 mm from touching on the other side. Could that be the problem? I took it off and noticed that not only was it touching part of the undercarriage now, it was in a bind pretty bad. It was difficult to remove the 2 nuts holding it on and when I got it off, I could see that there was definitely some rubbing going on. Took it for a test drive without the brace and whaddya know, no noise! The difference is that there is a metal bracket that mounts to the 2 flanges on the Berk HFCs. On the stock cats, I suppose it was in a different position by a few millimeters and didn't rub. After getting the Berks on, it rubs now.
Problem solved.
EDIT: Drive to work this morning with no noise at all. That was indeed the problem. Does anybody else have Berk HFC and a Tanabe under brace?
Problem solved.
On a different note, when I saw the location of this brace I thought it was useless because it didn't really stiffen anything. Wrong! I can tell the difference without it on the car.
OFF TOPIC: Just put your TB upgrade in the package to drop off on Monday.
i had something similar with my magnaflow rubbing with the underbrace.. I added some washers to move down the underbrace 1 or 2 cm's
problem solved.. not sure if it rides different though
It's actually rubbing by about 1 or 2 mm on the driver side and it looks like about 4 or 5 mm on the other side. I think I'm going to try the GT Spec brace and see if it gives more clearance. This one was pretty damn close to rubbing with the OEM cats and with the HFCs it does.
yesssss...very true!!!!i needed to shim my down also...
Hey BB does it sound like this? And it's not the muffler rattle all the other retards are talking about.
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/cfTIym7n9Hg&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/cfTIym7n9Hg&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
<embed src="http://www.youtube.com/v/cfTIym7n9Hg&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></object>
#29
<EMBED src=http://www.youtube.com/v/cfTIym7n9Hg&hl=en&fs=1 width=425 height=344 type=application/x-shockwave-flash allowfullscreen="true" allowscriptaccess="always"></EMBED>
#30
